Dart 496 or 540 - Team Camaro Tech
post #1 of 15 (permalink) Old Jan 27th, 10, 02:15 PM Thread Starter
Dante'
Dart 496 or 540
Planned on reduilding my 427 into a 468. After dissassembling the motor I discovered that the cylinder walls are trashed. Thinking on getting a Dart short block. 496 and 540 are the same price. Common sense says 540. What to do.
69 Camaro SS
windycity1 is offline
post #2 of 15 (permalink) Old Jan 27th, 10, 05:14 PM
Arch Stanton's Avatar
Re: Dart 496 or 540
540 all the way!!!!!
- John
Misfit tortured soul. Lone wolf. Unicorn.
'67 V8 Camaro - 12637, 797-Z (Parchment), M-M (Royal Plum), 2M, 3K, 5Y
Arch Stanton is offline
post #3 of 15 (permalink) Old Jan 27th, 10, 05:42 PM
Derek
Dereka's Avatar
Re: Dart 496 or 540
no replacement for displacement 540
Dereka is offline
post #4 of 15 (permalink) Old Jan 27th, 10, 05:49 PM
Steiner
Re: Dart 496 or 540
Is this a serious question?
Just kidding. You need to take a look at your whole setup and see what each is capable of, then plan accordingly. Will the 540 tip past what your powertrain and fuel system are rated for? If so, will you spend the money to get them up to snuff? If you're good to go either way then the choice would seem pretty easy. Is that on a tall teck block and will it fit?
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 15 (permalink) Old Jan 27th, 10, 05:52 PM
kt
kelly
Re: Dart 496 or 540
lol....if your gonna go big....go bigger....
kt is offline
post #6 of 15 (permalink) Old Jan 27th, 10, 09:05 PM
Alex
Re: Dart 496 or 540
what heads are you planning on using? if they can't flow enough for that 540 to breathe in the powerband your trans and rear are set up for you should go 496. otherwise, 540 all the way, but if your rear end, transmission, and rear suspension arent set up properly for it you'll just break stuff and fry tires while the guy next to you with the small block hooks his stuff up and wins.
69duskblueX33 is offline
post #7 of 15 (permalink) Old Jan 28th, 10, 12:06 AM Thread Starter
Dante'
Talking Re: Dart 496 or 540
Have not decided on heads yet although leaning towards AFR 305s. Camaros got 3 inch Magnaflow exhaust, Tremec TKO 600, Moser 12 bolt rear with 3.55 gear and frame connectors. The only concern I have is my fuel system I have a robb mac 1/2 inch sending unit with 8an braided line going to a Carter 170 high flow mechanical pump.
69 Camaro SS
post #8 of 15 (permalink) Old Jan 28th, 10, 01:40 AM
Steiner
Re: Dart 496 or 540
Pfffft. 540 all the way then. Next question.
1/2" or -8 is supposed to be good for around 700hp.
Is it going to be a tall deck or stock deck? I think tall decks have some fitment issures that have to be addressed.
'69 Camaro
500hp/538lbft
Steiner is offline
post #9 of 15 (permalink) Old Jan 28th, 10, 07:19 AM Thread Starter
Dante'
Re: Dart 496 or 540
Stock deck height.
69 Camaro SS
post #10 of 15 (permalink) Old Jan 28th, 10, 08:19 AM
Todd
Re: Dart 496 or 540
I agree with some here, is the rest of the car set up to handle a 540? If not, will you have the funds to swap it out. A decent 540 should put you over 700hp which brings different fuel systems, clutches, heads, carbs into play.
Vegas69 is offline
post #11 of 15 (permalink) Old Jan 28th, 10, 09:58 AM Thread Starter
Dante'
Re: Dart 496 or 540
My car is set up to handle the 540 but I'm still not sure which way I am going. Primarily street driven if it was a strip car 540 no question. What engine combo are you going with on your 69 to replace your 489?www.photobucket.com/Dantesrides
69 Camaro SS
post #12 of 15 (permalink) Old Jan 28th, 10, 10:41 AM
Todd
Re: Dart 496 or 540
I'm staying with a 489 in a ZL1 block. I can re use my heads, carb, hopefully fuel pump.
Vegas69 is offline
post #13 of 15 (permalink) Old Jan 28th, 10, 10:48 AM Thread Starter
Dante'
Re: Dart 496 or 540
Thats good, saves money. Thats the bad point if I go big, my carb, roller cam, and fuel system are too small.
69 Camaro SS
post #14 of 15 (permalink) Old Jan 28th, 10, 10:57 AM
Todd
Re: Dart 496 or 540
The same crank is used in a 496 and 540. If you have engine trouble or decide it's time, you can reuse the crank and rods as long as they are quality pieces.
Vegas69 is offline
post #15 of 15 (permalink) Old Jan 28th, 10, 05:44 PM
Steiner
Re: Dart 496 or 540
I don't know man. If it's primarily street, just use less cam to keep the power band on the milder side since HP is a function of torque and RPM. Then enjoy all that torque. The 540 should give you what....at the very minimum 50 lb ft more than the 496? For the same price?
Now this is just me, but I'd go with the biggest I could on the budget for a street car so the torque could be kept as high as possible and then work with the cam to keep the hp in check. Actually, I just went through all that with mine and put a deposit down yesterday.
'69 Camaro
500hp/538lbft
Steiner is offline
