Check out this fuel pump - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 28th, 10, 03:42 AM Thread Starter
Steiner
This may be a concept that has been visited before, I don't know. Was perusing the Retrotek site and ran across this mechanical fuel pump. Kinda expensive at $190 but looks cool and it sure improves on some of the line routing problems with some pumps.
Piston pump.
220 gph free flow.
Must be used with deadhead regulator as it flows at 60psi.
Flows only as much fuel as needed with no drop in RPM range.
Uses 20% of the force needed by a regular mechanical pump.
'69 Camaro
500hp/538lbft
Steiner is offline
post #2 of 8 (permalink) Old Jan 28th, 10, 04:31 AM
Marc
mnm99's Avatar
Re: Check out this fuel pump
Do a search... It's been talked about MANY times. Some people have luck with them but most don't.
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #3 of 8 (permalink) Old Jan 28th, 10, 06:13 AM Thread Starter
Steiner
I did one for "piston fuel pump" but only went back about 18 months and didn't see any titles that indicated they were about one hence the "This may be a concept that has been visited before, I don't know." Sorry. Please disregard post everyone.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 8 (permalink) Old Jan 28th, 10, 08:33 AM
i bought one of these for my tunnel rammed 327, haven't got the car running yet but would like to hear feedback about this pump. btw i bought my from competition products, they assured me its the same as the race pumps version, just a little less $$.
BLADE4444 is offline
post #5 of 8 (permalink) Old Jan 28th, 10, 12:57 PM
Marc
mnm99's Avatar
http://racepumps.com/
All sounds great..I got scared away when I started hearing of all the problems.
http://www.turbomustangs.com/smf/ind...?topic=77629.0
http://www.theturboforums.com/smf/in...topic=126464.0
http://www.theturboforums.com/smf/in...?topic=92725.0
mnm99 is offline
post #6 of 8 (permalink) Old Jan 28th, 10, 01:25 PM
Greg
Steiner, revise your search and look for "Race Pumps" like mnm referenced. Check several boards. I live about 30 minutes from the place and went as far as calling them to order it. The guy was headed out of town and asked me to call back on Monday. That weekend I did more searching and got so spooked I went a different direction.
Quick Fuel Technologies OEMs those pumps and claims they have had good luck but I saw too many horror stories....
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, 9:1, 10 PSI, Water/Meth injection
1.325 60', 5.988 @ 115.4 (carb)
Switched to Super Sniper EFI 2019
Greg O is offline
post #7 of 8 (permalink) Old Jan 28th, 10, 05:31 PM Thread Starter
Steiner
Thanks. I personally run an electric and FI so I couldn't use one but had never seen a piston pump before. Of course a lot of stuff falls into that category....
'69 Camaro
500hp/538lbft
Steiner is offline
post #8 of 8 (permalink) Old Jan 29th, 10, 04:45 AM
skelly
On on my second one now. My car now has 13 miles on it. It's lowd tapping sound caused me to remove the valve cover on that side three times before I realized it wasn't a valve tapping. This pump produces 50 psi and cause pulsation at the regulator. Gauge pulses approximately one and half psi at idle. I'll sell you mine when I remove it this weekend with the dead head regulator and all the paper work that goes along. This is a slimline product that fit when nothing else would, I installed the A/C compressor passenger side lower mount and a standard mechanical wouldn't fit. I'm also not particularly fond of the orings that are at the bottom of the machined ports smashed by the AN adaptors. Other than that I love it. Oh, I view this thing like some of those high maintenance women, they look great, but ?????? , who wants to deal with that ??????
skelly is offline
