Who makes a quite electric fuel pump? - Team Camaro Tech
post #1 of 13 (permalink) Old Jan 29th, 10, 05:25 AM Thread Starter
skelly
Externally mounted. Fuel cell in the car already. Can I install it in the engine compartment? Back 30 years ago, in my teenage days we mounted them in the trunk. I didn't really want an electric because of the noise but have had two horrible experiences with an Professional Products Piston pumps. I'm on my second one now. I've got 13 miles on my car. Ticking noise sounds like a valve tapping. Adjusted valves on that side three times before I realized it was the pump.
skelly is offline
post #2 of 13 (permalink) Old Jan 29th, 10, 05:32 AM
Bill
Re: Who makes a quite electric fuel pump?
Skelly,
What engine ? How many horsepower ? For most street applications a traditional block mounted pump like the ones that Carter, Holley and Edelbrock sell will be more than enough.
Most electric pumps do not like to "suck" meaning that they need to be near the fuel source and preferably below it so that they are gravity fed. So I would say under the hood is out. I am fairly sure that some of the newer gerotor type pumps ae a lot quieter than the old vane style ones. Only thing is I think most of those require a return line.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 13 (permalink) Old Jan 29th, 10, 10:41 AM
Marc
mnm99's Avatar
Bosch 044 pump. Reliable and quiet. Thats what I'm going to run on my twin turbo. Look it up.
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #4 of 13 (permalink) Old Jan 29th, 10, 11:36 AM
I used this one after I lost the fuel pump lobe on my cam. Worked well and tucked up neatly in the right rear corner of the body, next to the fuel tank.
http://www.jegs.com/i/Carter/180/P4600HP/10002/-1
TC # 349
zdld17 is offline
post #5 of 13 (permalink) Old Jan 30th, 10, 12:10 AM
How far above the bottom of the tank was the inlet to the Carter Pump? Wouldn't a fuel pump with the pump above the inlet be a better option? Something like a Jegs 15913?
Dave H. is offline
post #6 of 13 (permalink) Old Jan 30th, 10, 03:28 AM
Dave C
I have a Magnafuel on my car you can here it when the engine is off but not at all when car is running.
PRO.ST69orange
post #7 of 13 (permalink) Old Jan 30th, 10, 06:35 AM
Paul
which electric fuel pump would i want to run with a blower? i had some i was interested in getting with a filter setup but not quite sure if the blower will change which fuel pump i need? any help would be appreciated. the setup is a 496 with a 8-71 blower with dual 750's.
67cam427 is offline
post #8 of 13 (permalink) Old Jan 30th, 10, 09:05 AM
John Doe
dont use a jegs brand. i put one in last year. mine is super loud. ive tried many different ways to mount it an insulate it.
i may replace it this summer.
Bucknaked Racing is offline
post #9 of 13 (permalink) Old Feb 2nd, 10, 12:19 AM
Steiner
Not sure if that's the exact one that my buddy uses. However, he's got a couple of flathead '32 Fords and uses Carter because he says they work great and are quiet. He's got a Holley on his '40 Ford pickup with sbc/6-pack and said he's going to change it out to a Carter. That pump is LOUD but I don't know what kind of isolation he's using on the mount.
'69 Camaro
500hp/538lbft
Steiner is offline
post #10 of 13 (permalink) Old Feb 2nd, 10, 04:54 PM
Dave C
You need to size your pump according to HP....I think Magnafuel are about the best...
PRO.ST69orange
post #11 of 13 (permalink) Old Feb 5th, 10, 04:19 AM Thread Starter
skelly
355hp ZZ4. I'm unable to install a standard mechannical because of the location my builder choose for the A/C compressor. He installed a Professional Products Piston Pump. The first one failed at less than one mile on the car. I'm on the second one now, load tapping noise, must go. This is why I want to know what electric pumps are quite.
skelly is offline
post #12 of 13 (permalink) Old Feb 5th, 10, 04:23 AM Thread Starter
skelly
Additionally, I'm running into an issue locating a dust cover for the 700R4 locally. Any vendor's recommended?
skelly is offline
post #13 of 13 (permalink) Old Feb 5th, 10, 08:15 AM
Greg
My buddy has a Carter like mentioned above and it is louder than my Aeromotive A1000. The A1000 is quiter than the electric fan for sure. Once the car is on you can't hear it at all.
One big influencer on the electric pumps is how they are mounted. I mounted mine with a plate and rubber bushings.
The gerator style like the Mallory pumps are the quietest but I have never seen one in person.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, 9:1, 10 PSI, Water/Meth injection
1.325 60', 5.988 @ 115.4 (carb)
Switched to Super Sniper EFI 2019
Greg O is offline
