Professionally Paint or Spray Can? - Team Camaro Tech
post #1 of 38 (permalink) Old Jan 29th, 10, 11:56 AM Thread Starter
Taking my motor out and was wondering what is the best way to get show quality looking paint?
I do not professionally paint would have to send it out.
1969 Camaro Convertible 427 5 Speed
provfirescott is offline
post #2 of 38 (permalink) Old Jan 29th, 10, 12:19 PM
Marc
mnm99's Avatar
Re: Professionally Paint or Spray Can?
Whats your plan? Do you want it painted the same color as the car? or just chevy orange or just black? Orang or black do it yourself. Clean with acitone (sp) and paint. If your painting the same as the car send it out.
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #3 of 38 (permalink) Old Jan 29th, 10, 12:37 PM
Steps
There are many older posts that cover this in detail...Personally I use an air brush.
Steptoe is offline
post #4 of 38 (permalink) Old Jan 29th, 10, 02:29 PM Thread Starter
Going Chevy Orange.
post #5 of 38 (permalink) Old Jan 29th, 10, 03:54 PM
por 15... and a disposable brush. 2 coats of black por followed by 3 coats of their chevy orange engine paint. It will look great and last forever and be impervoius to all liquids, gas, brake fluid, everything. Only on the cast parts, steel parts need to be sprayed, brushstrokes will show.
post #6 of 38 (permalink) Old Jan 29th, 10, 04:15 PM
ratmotorred511's Avatar
That por15 is some wicked stuff if you us it wear a resperator but it is tuff as nails
93 Z28,76 LT, 69 prostreet Camaro 511bbc,400Turbo 8.75 Chry.5:13's,64 Vette drag car, 03 ZO6
ratmotorred511 is offline
post #7 of 38 (permalink) Old Jan 29th, 10, 06:48 PM Thread Starter
So you can spray the POR 15?
post #8 of 38 (permalink) Old Jan 29th, 10, 08:13 PM
Not without a forced fresh air respirator according to their web page.
69 Pace Car and 69 Hard top
srode is offline
post #9 of 38 (permalink) Old Jan 29th, 10, 08:37 PM
You can, but yes, a air supplied respirator is recommended. Outside in a stiff breeze might be fairly safe. It doesn't kill you quick, takes a while.
My motor doesn't have a lot of smooth steel parts left... Front cover is chome, manifold is alluminum, oil pan is anodized, etc...
When I first did it, I had Dart iron eagle heads and painted those also. The ends of these heads are machined smooth, and the brush strokes made me nutso.
My new AFR heads are alluminum, no problem there.
and the brush strokes don't show on the rough cast iron. Stuff if tough as nails, it's been 4 years, motor's been out and apart twice since I smeared it on. Stuff still looks like the day it was applied. Color is a lil different than spray bomb chevy orange.
If I had a factory oil pan, front cover, and valve covers, I'd consider spraying the por (out in the driveway on a windy day!) but would also consider other solutions.
also worth noting that por doesn't stick to smooth steel for nuttin. It likes a surface with some bite. hit that oil pan HARD with a coarse wire brush. Or consider another solution.
post #10 of 38 (permalink) Old Jan 31st, 10, 05:21 PM
If you decide to bomb-can it, VHT is excellent.
BPOS is offline
post #11 of 38 (permalink) Old Jan 31st, 10, 07:38 PM
Bill
bill3337's Avatar
I ground mine smooth, coated it with high solids primer, sanded it out and base/cleared it.....been in 12 years looks as good as the day it was painted.
bill3337 is offline
post #12 of 38 (permalink) Old Jan 31st, 10, 07:46 PM
Wayne
Has anyone tried the Eastwood's ceramic engine paint?
Wayne
69 Camaro SS/RS. Fab 9. GM LSA/485 crate drive train. . C6 Z51 brakes. AirRide G bar Rushforths 18x8 19x12
Motown 454 is offline
post #13 of 38 (permalink) Old Jan 31st, 10, 08:00 PM
Jerry R.
jr68's Avatar
I'd go spray can
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #14 of 38 (permalink) Old Jan 31st, 10, 08:42 PM
Jeremiah
I use PPG DP90 metal etching sealer reduced and finish with PPG base/clear. Any other high quality base/clear finish should get you approx results. It will last several times longer, it will not discollor, stain or lose its gloss and adhesion is superior. Even brake fluid will not harm a lot of the newer clear coats.
Most importantly I use about half a gallon of degreaser through a cheap paint gun to clean the engine before hand and blow it dry.
I have had my share of trying different rattle can finishes and didnt like the results with any of them. I have also used POR products and didnt care for them.. I havnt tried the engine paint though.
If you want it to look like it was just painted yesterday years down the road a good quality base/clear is the best method IMO.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #15 of 38 (permalink) Old Feb 2nd, 10, 01:28 PM Thread Starter
Doesnt look like Spray bomb is what I am after(Quality) so might just send it out to have painted.
Stripping it as we speak.
