Rotating Assembly Mystery - Team Camaro Tech
post #1 of 14 (permalink) Old Jan 30th, 10, 12:10 PM Thread Starter
Gary
Guys....I know I'm not giving you much info here, but what's everyone's guess as to the internal specs of this motor. The pistons feel like they are a dish style. I never took the heads off but they are 461 castings. The underside of each piston had Sharpie markings...1 through 8. I know it's a 350, 1977ish, 2pc main block. Also, any guesses on the the horsepower I should be expecting? It has headers, 2 1/2" Flowmasters, Holley 670 SA, no-name polished hi-rise, Comp Thumper(479/465 lift), Perteronix Ign, M20, 3.42 12-Bolt. Thanks
Gary
Gar's67 is offline
post #2 of 14 (permalink) Old Jan 30th, 10, 12:39 PM
Daryl
1968RallySport's Avatar
Re: Rotating Assembly Mystery
one would need to know what pistons you have and the cam specs to estimate HP. Sorry
1968RallySport is offline
post #3 of 14 (permalink) Old Jan 30th, 10, 04:31 PM
Tim
77wolf10.85's Avatar
No, but I can tell you that in your 2nd pic the engine was about 30 or so btdc #1.
Tim Smith
77wolf10.85 is offline
post #4 of 14 (permalink) Old Jan 30th, 10, 04:35 PM
Bill
Looks stock to me
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #5 of 14 (permalink) Old Jan 30th, 10, 04:38 PM
Cast crank, and pistons.
john68 is offline
post #6 of 14 (permalink) Old Jan 30th, 10, 04:40 PM
Tim
I agree Bill, and I can't see that any rods have ever been balanced. Can't see the parting line on the crank either. The 1 piston skirt you can see looks good.
Tim Smith
post #7 of 14 (permalink) Old Jan 30th, 10, 06:24 PM
Bill
Tim,
If you look at the counterweights on the far right in the picture you can see the parting lines, definitely a cast crank.
Bill Koustenis
Owner
Waldorf Md
BillK is offline
post #8 of 14 (permalink) Old Jan 30th, 10, 06:46 PM
Butch
Looks like cast crank and stock or stock style pistons, stock rods too
Are they 461 or 461X heads?
href="
target="_blank">www.prosystemsracing.com
trmnatr is offline
post #9 of 14 (permalink) Old Jan 30th, 10, 07:16 PM
Stock motor and pistons I would assume - and a little bit of cam - maybe 350 -375hp.
69 Pace Car and 69 Hard top
srode is offline
post #10 of 14 (permalink) Old Jan 30th, 10, 07:18 PM Thread Starter
Gary
461 for sure...no "X"
Gary
Gar's67 is offline
post #11 of 14 (permalink) Old Jan 31st, 10, 03:48 PM
Charlie
Unless someone swapped the pistons, they are probably dish. Let me ask you this, how well does it run on 87 octane? If ok, that would rule out a real high comp motor. If this is a stock 77ish, that would make you somewhere around 7.6:1 static, using stock internals. Not good at all. We all know in 71 they went from high to low compression. My stock 71 350 has a dish piston and a 76cc open chamber combustion chamber that makes around 7.6:1 static compression. Now, if someone changed the pistons, it's impossible to tell. That cam is way too big, IMO. That combined with the not so hot rear end ratio makes for a pig off the line. I used CamQuest and going with a 62cc chamber 2.02/1.6 valve head, high rise high flow intake, dual exhaust w/mufflers and no cats, 18cc dish piston, .039" thick head gasket, cylinder bore of 4.000", gasket bore of 4.125", stock deck height of .025", stroke of 3.48, an intake valve closing of 50*ABDC and that got me a static ratio of 8.6:1. I got a peak hp of 334 and a peak torque of 365. This is at the flywheel so take away about 33hp and 36ftlbs. if you use a drivetrane loss of 10%. If you use a loss of 15%, take away 50hp and 55ftlbs. Much better than if you would have an auto tranny.
IMO, that cam is too much for those heads. Not to mention that cam technology is made for newer design heads. If you would switch to something like the L-79 cam or maybe the 30-30, you would get better results. IMO, you are combining 2 different design eras. Either switch to newer heads or an older designed cam.
67CamaroRS/SS is offline
post #12 of 14 (permalink) Old Jan 31st, 10, 03:54 PM
Charlie
According to Chevy-Camaro.com, that block is 77-79, 2 or 4 bolt main and UP TO 225hp. Used in Corvettes and others.
post #13 of 14 (permalink) Old Jan 31st, 10, 06:36 PM
JohnZ's Avatar
That block was never used in any Corvette.
JohnZ
CRG
JohnZ is offline
post #14 of 14 (permalink) Old Feb 1st, 10, 07:27 AM
Charlie
Then Chevy-Camaro.com is wrong.
