Fully dressed 327 engine weight - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 30th, 10, 12:36 PM Thread Starter
Bob
Does anyone know where I can find this data? Also w/M21 attached? Need to pull motor in the spring to replace rear main seal and want to make sure I buy the right engine hoist the first time!
Thanks in advance
Reddize
reddize is offline
post #2 of 5 (permalink) Old Jan 30th, 10, 12:40 PM
Daryl
1968RallySport's Avatar
Re: Fully dressed 327 engine weight
between 750 & 850 lbs.
1968RallySport is offline
post #3 of 5 (permalink) Old Jan 30th, 10, 01:09 PM
Thanks in advance
Reddize
Save yourself the headache, get this,
http://www.harborfreight.com/cpi/cta...emnumber=35915
This one is collaspable for store in a small corner in your garage.
And an engine leveller lift that attaches to the floor unit. You can angle the engine and transmission together to pull or install in one piece. Looks something like this
http://bigdogtoolz.com/su5208.html
Harbor Freight may have this also.
TC # 349
zdld17 is offline
post #4 of 5 (permalink) Old Jan 30th, 10, 04:12 PM
Dana
750 lbs. sounds more like a BBC, aren't SBC's more like 575?.
RSCopo is offline
post #5 of 5 (permalink) Old Jan 30th, 10, 04:46 PM
Lee
mrmuncie's Avatar
The muncie is about 75 lbs
Lee (in Louisville, Ky)
Second owner 69 SS Camaro 350 A/C Stick
I specialize in Muncie 4 speeds. Rebuilding tranys for 20 years with over 50 Muncies to select from. If your looking for a certian date code I should be able to help.
mrmuncie is offline
