Which roller rockers? - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 31st, 10, 05:07 AM Thread Starter
Tony
Guys;
I'm looking at roller rockers for my 302 build. I see them listed as 5.1:1 and 6.1:1 with 7/16" studs. Can someone describe the differences here, and which would be correct for my mostly stock 302 application? Thanks very much.
Tony's '69 -
69RS/Z28 is offline
post #2 of 12 (permalink) Old Jan 31st, 10, 05:09 AM Thread Starter
Tony
Re: which roller rockers?
Sorry; 1.5:1 or 1.6:1.
Tony's '69 -
69RS/Z28 is offline
post #3 of 12 (permalink) Old Jan 31st, 10, 05:14 AM
1.5-1 would be correct but check if you have stock heads they might have 3/8 studs.
ssdoug is offline
post #4 of 12 (permalink) Old Jan 31st, 10, 05:34 AM
I would recommend Comp Cams Magnum rockers - they are stamped like the OEM but roller tipped and more rigid than origional - fit 3/8 studs which you most likely have and are 1.52:1 ratio. They will fit a stock or slightly larger valve spring with no intereference problems and are very reasonable - like $170 per set
69 Pace Car and 69 Hard top
srode is offline
post #5 of 12 (permalink) Old Jan 31st, 10, 05:38 AM Thread Starter
Tony
Thanks Guys! 3/8 studs, meaning the studs that hold the rockers on themselves? I will check out the comp cams ones; sounds like a good deal. I was looking at Rick's for like $380.00.
Tony's '69 -
69RS/Z28 is offline
post #6 of 12 (permalink) Old Jan 31st, 10, 05:52 AM
Yep, 3/8 is the stud that holds the rockers.
srode is offline
post #7 of 12 (permalink) Old Jan 31st, 10, 05:55 AM Thread Starter
Tony
I'm looking at a part number 1417-16 from Comp. Cams - is this the correct part number? $198.00 with free shipping. Thanks very much.
Tony's '69 -
69RS/Z28 is offline
post #8 of 12 (permalink) Old Jan 31st, 10, 01:25 PM
James
We had to set the aluminum needle bearing ones up in a milling machine and clearance them for larger springs.
James
"Collectin' Camaro's since only Rednecks Drove them"
firstgenaddict is offline
post #9 of 12 (permalink) Old Jan 31st, 10, 01:43 PM
Butch
I like Crane "Gold Race" roller rockers for a performance application
If its more "Street" the Comp or Crane "Gold Race" will work fine
href="
target="_blank">www.prosystemsracing.com
trmnatr is offline
post #10 of 12 (permalink) Old Jan 31st, 10, 02:00 PM
Re: Which roller rockers?
If you have guide plates - the 1412-16 part number will work and are about $40 less - if no guide plates for the pushrods then the 1417-16 is the right part number because they are self aligning. Summit has the 1417-16 for less $177 plus shipping which is probably $10.
srode is offline
post #11 of 12 (permalink) Old Jan 31st, 10, 04:43 PM
Do it once and for all , spend a few bucks more and go for pro magnums. These are rebuildable .
TC # 349
zdld17 is offline
post #12 of 12 (permalink) Old Feb 1st, 10, 07:43 AM Thread Starter
Tony
thanks for all the input guys!
Tony's '69 -
69RS/Z28 is offline
