Thrown rod...can the block still be used?? - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 1st, 10, 12:03 AM Thread Starter
I have a chevy 350 1974 and the #5 rod was thrown partially out of the oil pan. After removing the pan the only major damage that could be seen was on the very bottom of the #6 cylinder it had a small chip the size of half of your pinky nail broken off.... Can I just smooth the edges and do a rebuild or is that enough to kill it?? Thank for your help. I will post pics tomorrow
life4christt is offline
post #2 of 7 (permalink) Old Feb 1st, 10, 04:41 AM
Banned
Re: Thrown rod...can the block still be used??
That should not hurt anything,
CNC BLOCKS N/E is offline
post #3 of 7 (permalink) Old Feb 1st, 10, 04:59 AM
Michael Gekko
Life,
When you take the block to the machine shop just get them to check it for cracks to be sure.
Eleanor's Nemesis is offline
post #4 of 7 (permalink) Old Feb 1st, 10, 05:58 AM
Rich
Only way to know for sure it to have it checked.If it isnt leaking water and it is as small as you say,then you can clean up the edges and use it.I might be concerned if it were a short rod 383 since the piston skirts come further out of the bore,but in a 350 you should have no issues with a small chip.I have seen guys fix some really wrecked stuff.I have seen blocks banged right into water where the owner had a ton of machine work in it and would sleeve the one hole and then half fill the block.Thrown rods are always a train wreck.Back when aluminum rods were more common there were more thrown rods,but less damage.Now almost all bracket engine builders use steel rods,which hold up better,but when they go,they really go.Good luck with fixing your block.
RichSchmidt is offline
post #5 of 7 (permalink) Old Feb 3rd, 10, 05:10 AM
Gary
Sometimes you wish they'd break...
I saw an aluminum big block with steel rods once that had a piston break right at the pin boss. The steel rod all but sawed the block in half. If it had broken, he'd still have a useable block, but it still made for quite a conversation piece in the shop. Some idiot came in and offered him a grand for it, so it's now someone else's mechanical failure sculpture.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Busted Knuckles is offline
post #6 of 7 (permalink) Old Feb 3rd, 10, 05:12 AM
BILL
SPARKY69's Avatar
I think by what you are saying it should be ok!!
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #7 of 7 (permalink) Old Feb 3rd, 10, 10:15 AM
Smile Re: Thrown rod...can the block still be used??
Is it below where the rings on the piston stop, when they are moving in the bore ? Is it even where the piston may contact ? Remember, not all of the cylinder is actually used.
TJS69 is offline
