solid roller cam - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 1st, 10, 06:41 PM Thread Starter
Keith
solid roller cam
how often should I adjust the valve lash?
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #2 of 4 (permalink) Old Feb 1st, 10, 06:50 PM
Re: solid roller cam
A correctly lashed solid lifter set up should not need to be adjusted as frequently as one might think. If you have all quality parts and good lubrication once a season of street flogging should be fine. Poly locks done right should not loosen. Crush nuts on the other hand might require more maintenance. ...... IMHO
1969 Nova SS, all motor BBC with C Straub girly cam, AutoGear M23W, 4:10
jmartorana is offline
post #3 of 4 (permalink) Old Feb 1st, 10, 07:35 PM
Steve69SS396's Avatar
It depends. When I used my car as a daily driver I would check the lash every 3 months. Now that I don't drive it all the time I only check it before I take it to the track.
Steve69SS396 is offline
post #4 of 4 (permalink) Old Feb 4th, 10, 08:29 PM Thread Starter
Keith
thanks for the info...had some trouble this year, and found oout that the lash needed ot be adjusted...did not even realize that the motor was a solid lifter cam until this year (got it out of a donor drag car that I bought on the cheap a few years ago). 383 stroker--complete roller setup, also grabbed the rear-end out of the same donor car ('79 Skylark).
Anyway, long story short, after the lash adjustment his summer, the thing runs better than ever...It ha sbene in the car for about 6 years, but has probably seen less that 4-5K miles (yeah, I know it's a damn shame --I'm working on it!
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
