solid lifter soak? - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 2nd, 10, 02:26 PM Thread Starter
Chris
solid lifter soak?
I am putting back together my stock 69 Z28 302. I am using a new GM performance stock grind camshaft and new solid lifters that came with it. Is it a good idea to soak those lifters in oil before installing them?
Thanks,
Chris
Chris Clark is offline
post #2 of 3 (permalink) Old Feb 2nd, 10, 02:47 PM
Vintage 68's Avatar
Thumbs up Re: solid lifter soak?
Not necessary for solids.
Just make sure you use a good assembly lube on the cam and lifter bases. I like "Red Lines" assembly paste and apply it with a small good soft brush.
A few friends are using the new Permatex product and like it so far.
I like to squirt the lifter bores down with a little fresh 5w oil prior to installing the lifters - either solids or hydraulic - to make sure they can move freely in their bores to rotate during the first few revolutions as I manually crank the engine over prior to and during pressure pre-lube.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 3 (permalink) Old Feb 2nd, 10, 05:44 PM
Harry
dawg's Avatar
make sure you coat the hell out of the cam lobes and lifters.
also a good idea to use some zinc additive in your breakin oil
434 stroker
US Navy retired
dawg is offline
