Looking for input, New Build - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 2nd, 10, 07:22 PM Thread Starter
Nick
I will be building in the next few months and was wondering if you guys could give me a little help.
What I want to accomplish- I am looking to get around 450 horse 450 torque, not to crazy but I want it to be there when I want.
What I have- I am starting off with a 69 4 bolt main 350, Dart IE 64CC,202/190,210cc. I have a performer intake and edelbrock 750 electric choke.
I want to bore and stroke this motor to a 383. Is it possible for me to get to those numbers with the setup I have, I know that the cam will be a decisive factor with this, I have not chosen a cam so any input would be greatly appreciated. My wife and I are expecting are first child within the next two weeks so I have to be budget concious.
The car is an original 327 4 speed car and has been in my family since 1972. Being that I don't want to beat up on the original engine I am going to pull it and crate it up for safe being.
Thank you ahead of time for all your input and I look forward to hearing what you come up with.
Nick
elk_aholic is offline
post #2 of 10 (permalink) Old Feb 2nd, 10, 07:33 PM
AJ
Re: Looking for input, New Build
First thing is your gonna have to loose the 750 edelbrock, it prob wouldn't support close to 500 horses.
Are the heads 2.02/1.60 valves? Or are the 190cc or 200cc runners, I don't understand that part in your post. You can't have 2.02" intakes and 1.90" exhaust valves.
You are probably going to want a good roller cam, or large solid flat tappet cam if money doesn't allow for a roller.
somewhere around 10.5:1-11:1 comp, around .550" lift, and maybe some mild head work will get you 450 no doubt.
Get the block checked and machined thoroughly, decked and so on...
Look @ scat for a rotating assembly, they are pretty good and will save you some money, also callies is good.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #3 of 10 (permalink) Old Feb 2nd, 10, 07:35 PM
forget about the numbers and build to the application. 450 & 450 sounds nice, but at what rpms?
What trans will you use? what gearing? What will you do with the car?
And yes, a nicely built 383 will do that and more, though I dunno about this budget crap.
mine will spin to 7k, run 12's, get 23 mpg on the highway, and lug down under 2000 rpm pulling a 2:1 final drive (3.08 gear, .64 OD, really.)
Compression / drcr / cam duration: You want to get the DCR up around 8.5:1, so shoot for 10:1 - 11:1 static depending on the cam.
Heads: An "all purpose motor" like mine needs efficient heads, heads that will produce high flow & high velocity, and not fall flat at low rpm. I run AFR 295 elimitators.
Valvetrain: Lots of thoughts here, and most will get the job done. I run a fairly short hydraulic roller with .550 lift and 110 lsa. My valve train is very very light, that helps the HR rev. A solid flat tappet setup works almost as good for 1/3 the dollars.
Tuning: Tuning is everything. I cheated and put on a cheap laptop tunable EFI system. Alternative is to marry a holley guru who owns a sun distributor machine.
post #4 of 10 (permalink) Old Feb 2nd, 10, 07:43 PM
Michael Gekko
Nick
Honestly, if I were you I would go into the member classifieds here at TC and take a good look at MKelcy's 383 for sale....it hits the HP you desire and can't be built for what he is asking. Hardly any time on it and high quality parts.
Eleanor's Nemesis is offline
post #5 of 10 (permalink) Old Feb 2nd, 10, 07:48 PM
He hasn't sold that yet?
I've followed the engine over the beartooth mountains (google it or search this site for the pics and the story.) That is a solid setup without a doubt.
Somebody should buy that motor.
post #6 of 10 (permalink) Old Feb 2nd, 10, 07:54 PM
Jody
camcojb's Avatar
sold to a friend of mine, we're picking it up Saturday.
Jody
camcojb is offline
post #7 of 10 (permalink) Old Feb 2nd, 10, 07:55 PM Thread Starter
Nick
I just checked on it and it sold! Sorry about that 2.02/160 with 200cc runers.
It has a saginaw 4 speed sportin 3.73 gears in the rear. The car will be a street cruiser it will see very little strip time. I just want a reliable street car that I can pound on every once in a while.
How do I determine SCR vs DCR?
Also if you guys could excuse my ignorance and help me understand on how to read a cam it would be great.
post #8 of 10 (permalink) Old Feb 2nd, 10, 08:00 PM
Michael Gekko
If I was in the slightest need of a street friendly SBC I woulda pulled the trigger on it. Well, as long as he painted it a color other than yellow
post #9 of 10 (permalink) Old Feb 2nd, 10, 08:02 PM
Those are some BIG SBC heads.
Mike - '68 Camaro with lots of stuff done to it.
Mkelcy is offline
post #10 of 10 (permalink) Old Feb 2nd, 10, 08:15 PM
AJ
Static is the constant value, what most people say when you ask them the comp of their motor "oh it's 10:1" and so on, DCR is always lower than static and is determined by the cam's valve timing.
Find a calculator and input cams that get you a DCR from 8.1-8.5
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
