Holley Carb 600CFM w/electric choke - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 3rd, 10, 01:25 PM Thread Starter
Question Holley Carb 600CFM w/electric choke
I 'm building a SBC 350, w/.040 flat top dished pistons, 462 heads-64cc w/2.02 intake-1.5 exhaust valves, threaded rocker studs & valve guide plates, Z28 valve springs, solid lifters, LT-1(70's Camshaft) (39721780).459/.458 lift; 316/336 duration; [email protected] .050"; 116LC Lobe Seperation and a 1969 Z28 aluminum intake. Can I ugrade the Holley 600CFM to meet the carburation needs of this motor, or would it be better to go to a 670CFM Carb.
Just reading other inputs I think a 780CFM might be over kill!
All inputs would be appreciated and thanks ahead of time!
jlighthart is offline
post #2 of 3 (permalink) Old Feb 3rd, 10, 01:37 PM
Re: Holley Carb 600CFM w/electric choke
670 sounds goods with E-choke. Unless you start changing stuff again, 700 range.
TC # 349
zdld17 is offline
post #3 of 3 (permalink) Old Feb 3rd, 10, 07:04 PM
DT
Donny
DT's Avatar
GO to Holley.com. They have a carb recommendation selector tab. Just answer the questions they ask.
DT is offline
