HEI Clearance on a BB - Team Camaro Tech
post #1 of 11 (permalink) Old Feb 3rd, 10, 07:06 PM Thread Starter
DT
Donny
DT's Avatar
Anyone have any clearance issues with a HEI distributor on a 69 BB ??
DT is offline
post #2 of 11 (permalink) Old Feb 3rd, 10, 07:19 PM
Talking Re: HEI Clearance on a BB
Of course, HEI's did not come out until 1975. Why should it fit ? Use a small bodied HEI or a points distributor converted to an electronic. (Pertronix) Option 2 is to dent the firewall.
TJS69 is offline
post #3 of 11 (permalink) Old Feb 3rd, 10, 07:31 PM
AJ
If you have good body mounts and trans mount it should clear, at least on a sbc, but given the different frame mounts of a bbc, I don't see why it wouldn't fit with new body and trans mounts.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #4 of 11 (permalink) Old Feb 3rd, 10, 07:31 PM
I have a 67 coupe with 69 BB frame mounts and I initially had a DUI HEI in it. In my car I had at least 1/2 inch clearance between the full size HEI and the firewall. If you can find someone that has an HEI laying around, try it and see if it fits.
be6207 is offline
post #5 of 11 (permalink) Old Feb 4th, 10, 09:16 AM
I have a HEI in my 67 RS/SS 396, and it fits fine.
1967 RS/SS 396 4 Speed (All Stock)
Journey is offline
post #6 of 11 (permalink) Old Feb 4th, 10, 11:34 AM
Eric
I also have an HEI in my 69/396 and it fis fine. Big block motor mounts and new frame mounts
Eric
EN69SS396
Yellow 1969 Coupe BB396/Turbo 400
en69ss396 is offline
post #7 of 11 (permalink) Old Feb 4th, 10, 11:44 AM
Camarodude67
I have 1969 RS/SS Big Block and Small Block Verts and no problems plenty of room for HEI.
Jeff G.
69 Verts
camarodude67 is offline
post #8 of 11 (permalink) Old Feb 4th, 10, 02:13 PM Thread Starter
DT
Donny
DT's Avatar
Thanks guys.
DT is offline
post #9 of 11 (permalink) Old Feb 4th, 10, 03:08 PM
I guess a picture is worth a thousand words. This is an HEI in a 68 I had. Original BB engine frame mounts.
67 3L 4P Project Car
I just had to have some wings.
67 RS/SS Pictures
cpodeep is offline
post #10 of 11 (permalink) Old Feb 5th, 10, 07:52 AM
jason
if you have the correct frame mounts it will fit just fine.
68z28sd is offline
post #11 of 11 (permalink) Old Feb 5th, 10, 02:45 PM Thread Starter
DT
Donny
DT's Avatar
Thanks again. I thought I would be OK. Ricks 1st states I would have to dent the firewall.
DT is offline
