Holley ID - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 9th, 10, 01:07 PM Thread Starter
Keith
Holley ID
Can someone tell me how to identify an older Holley carb, a friend has one and asked me, I wasn't sure. There are numbers stamped at lots of different locations and not sure which one actually tells what model it is? Where would the identifying number be located on the carb. Thanks
BK69 is offline
post #2 of 6 (permalink) Old Feb 9th, 10, 01:09 PM
Bri
bwcamaro68's Avatar
Re: Holley ID
Some info for Holly ID
http://www.mortec.com/carbs.htm
"Three Rules of Work: Out of clutter find simplicity; From discord find harmony; In the middle of difficulty lies opportunity."
Albert Einstein
"Never Forget" FDNY 9/11/01
I have more than 4 Camaro's am I Addicted?
bwcamaro68 is offline
post #3 of 6 (permalink) Old Feb 9th, 10, 01:47 PM
Jody
camcojb's Avatar
Re: Holley ID
usually on the choke housing, says List and then followed by the part number of the carb.
Jody
camcojb is offline
post #4 of 6 (permalink) Old Feb 9th, 10, 02:07 PM
Bryon
bcm66's Avatar
Re: Holley ID
Yep, numbers are on the top part of the carb. The area where it is will be covered up if there is an air cleaner on it. If you can't find the decode on the Holley site, post a picture or the numbers and we can help you out.
Here is a link to images for the location.
http://www.holley.com/TechService/ListNumber.asp
Here is the list number ID information
http://www.holley.com/data/TechServi...%20Listing.pdf
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #5 of 6 (permalink) Old Feb 9th, 10, 03:23 PM Thread Starter
Keith
Re: Holley ID
Thanks for the info, I pulled the numbers and it was list 6210-3 and date was 2675, according to Bryon's holley info it was a 650cfm carb, this is what I needed to know, thanks again
BK69 is offline
post #6 of 6 (permalink) Old Feb 9th, 10, 04:51 PM
Jonesy's Avatar
Re: Holley ID
Thats a Holley 4165 replacement for all Chevrolet 327-402 engines and you are correct , it is 650 CFM.
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
Jonesy is offline
