68 frame mount/motor mount question - Team Camaro Tech
post #1 of 14 (permalink) Old Feb 9th, 10, 01:25 PM Thread Starter
I have a 68 that had a BB in it and I'm in the process of putting in a SB. My problem is with the BB frame and motor mounts the oil pan is hitting the cross member. Will SB frame mounts raise the motor? Another question would be what combo of mounts would give me the most clearance?
OK after some research it looks like I need 68 302/327 frame mounts. Is this the correct thinking?
Thanks for the advice
Last edited by Zammer217; Feb 9th, 10 at 01:48 PM. Reason: did some research on this site
Zammer217 is offline
post #2 of 14 (permalink) Old Feb 9th, 10, 02:02 PM
Smile Re: 68 frame mount/motor mount question
In 67 + 68 the small blocks all used the same frame mounts. These are different then the Big Block mounts. When you install the engine, if your harmonic balancer hits your stock sway bar you must add some washers between the engine mount and the engine block. If your sway bar is larger then the stock one, you will have to shim that down.
TJS69 is offline
post #3 of 14 (permalink) Old Feb 9th, 10, 02:05 PM
red
My brother had a 68 BB car with a sb in it, and motor sat low. Is your car a 4 speed? I have a set of sb 67 frame mounts new.
red67L78 is offline
post #4 of 14 (permalink) Old Feb 9th, 10, 02:25 PM
Bryon
bcm66's Avatar
Doug - is it a stock oil pan?
I know back in the 70s we would swap a 302 and a 396/375 hp engine fairly regularly in a 67 with no issues, other than having to use that washer trick sometimes. But normally didn't have to. If it has a stock oil pan I can't image why it would be hitting the cross member.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #5 of 14 (permalink) Old Feb 9th, 10, 02:36 PM Thread Starter
No it is not a stock oil pan it's a Moroso 7qt.
post #6 of 14 (permalink) Old Feb 9th, 10, 03:45 PM
Not all 67 68 small block motor mount frame stands are the same . 350 & 302 were the same and 327 were different . They were shorter front to back. So you couldn't put a 327 motor mount on a 350 or 302 frame stand . The 396, 350 ,302 motor mount will all work together.
67 royal plum L78 11.70's @115
69 RS Z28 cross-ram
68 convt. all orig 2nd owner
67 396 royal plum impala 4spd parchment int
green z is offline
post #7 of 14 (permalink) Old Feb 9th, 10, 06:03 PM
I am not sure on the original equipment frame stands, but this chart shows that the stands were the same. The engine mounts were different on the 302/350. Frame stands are brackets and mounts are engine mounts.
The 69' 302/350 frame mounts and engine mounts were the short and narrow style when GM redesigned their problem prone 327 mounts in High performance applications.
TJS69 is offline
post #8 of 14 (permalink) Old Feb 9th, 10, 06:26 PM
Bryon
bcm66's Avatar
The problem is the oil pan, not the stands or mounts.
CRG -
bcm66 is offline
post #9 of 14 (permalink) Old Feb 9th, 10, 06:50 PM
Right you are ! Get a stock pan !
TJS69 is offline
post #10 of 14 (permalink) Old Feb 9th, 10, 10:43 PM Thread Starter
OK a little more info. It's not a stock SB it's a 383 with I-beam rods so I need this pain for the extra stroke clearance. Any ideas now....I really don't want to mod the cross member.
post #11 of 14 (permalink) Old Feb 10th, 10, 07:19 AM
There are other pans that are shorter in the front, that will clear 3.75 cranks. I am not sure if the I beam rods create a problem at the pan rails. If they do, you may be able to grind clearance at the pan rail ?
http://www.milodon.com/oil-pans/stre...ns-sbchevy.asp
http://www.moroso.com/catalog/catego...?catcode=11000
TJS69 is offline
post #12 of 14 (permalink) Old Feb 10th, 10, 08:08 AM
red
Give us an idea of what amount of clearance you need. See if jacking up a little would help. My thinking is getting some tall solid motor mounts on top of sb 67 frame mounts.
red67L78 is offline
post #13 of 14 (permalink) Old Feb 10th, 10, 08:51 AM Thread Starter
I need to raise it about 1/2 to 3/4 of an inch. I will see if I can get the garage warmed up today and double check. Built a new garage but did get around to getting a heater installed yet so it's a little cold.
post #14 of 14 (permalink) Old Feb 10th, 10, 11:12 AM
Bryon
bcm66's Avatar
What length rods did you use - 5.7 or 6 inch? I know lots of people with 383s and some run stock oil pans.
CRG -
bcm66 is offline
