350 - LT1 or L98 - Team Camaro Tech
post #1 of 11 (permalink) Old Feb 10th, 10, 03:57 AM Thread Starter
Brent
67Rally's Avatar
350 - LT1 or L98
Hey guys, just picked up a '67 Rally Sport with a small block 350 in it. The guy I bought it from said he thought it was an LT1 engine, but he also said it came out of an '87 Corvette (which I think came with the L98).
I'm just trying to figure out which engine it is. Are there any visual differences that would distinguish the 2 engines? I can post a pic later if it helps. Thanks.
67Rally is offline
post #2 of 11 (permalink) Old Feb 10th, 10, 05:54 AM
Chad
67 Plum's Avatar
Re: 350 - LT1 or L98
1987 Vette had a L98 LT1 started in 92.L98 has the distributor in the rear an LT1 has it in the front.An LT1 can be changed to the rear but their are no cooling passages in the intake manifold so the top radiator hose doesn't connect to the intake.
67 Plum is offline
post #3 of 11 (permalink) Old Feb 10th, 10, 06:39 AM
Steiner
Don't quote me but I believe and L98 has angled plugs while the LT1's were straight. The only LT1 I ever had was a transplant in a '90 K5 Blazer and I didn't keep it long enough to even get to the plugs.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 11 (permalink) Old Feb 10th, 10, 06:50 AM Thread Starter
Brent
67Rally's Avatar
Does that mean you're not a fan of the LT1's or was it just a bad motor?
67Rally is offline
post #5 of 11 (permalink) Old Feb 10th, 10, 06:51 AM Thread Starter
Brent
67Rally's Avatar
Thanks. Distributor is in the rear, I'll check the radiator hose location when I get home.
67Rally is offline
post #6 of 11 (permalink) Old Feb 10th, 10, 06:59 AM
joe
I had one in my 94 caprice which is now in my 68 camaro. The caprice was pretty damn quick for a 4200 lb car. Never had any problems with that engine. Camaro is not ready yet. Easy install in the camaro.
balljoint is offline
post #7 of 11 (permalink) Old Feb 10th, 10, 07:16 AM
Rich
The LT1 was a great engine,the only real downside was the trouble prone optispark ignition that there was no good fix for.The biggest power advantage for the LT1 was that it had heads that were similar to the Vortec truck heads,and the intake design was better.You can make plenty of power with your L98.You can switch to a set of Vortec heads and have them prepped for a large cam,and run the Vortec TPI intake with some larger injectors.Swap in a mild computer compatable cam{if you still have the injection} and adjustable fuel pressure regulator,headers and a good exhaust system,a chip and a cold air induction system and you will have an engine that runs better then any stock LT1.
400 HP and super good daily driveablity should be doable with this setup.
RichSchmidt is offline
post #8 of 11 (permalink) Old Feb 10th, 10, 07:24 AM
Steiner
It was a total sh!tbox all the way around, not the motor's fault. Transmission went out as soon as I got it. Motor blew a week after I sold it. The seller disclosed some "wrist pin noise" after I bought it. Nice suspension, bad powertrain. The only time I've been burned by a vehicle purchase on eBay.
'69 Camaro
500hp/538lbft
Steiner is offline
post #9 of 11 (permalink) Old Feb 10th, 10, 07:29 AM
Chad
67 Plum's Avatar
L98s with cast iron heads have straight plugs the aluminum headed ones have angle plugs.
67 Plum is offline
post #10 of 11 (permalink) Old Feb 10th, 10, 10:30 AM Thread Starter
Brent
67Rally's Avatar
No TPI any longer, it has a Holley Street Avenger Carb on it with an Edelbrock RPM Intake.
67Rally is offline
post #11 of 11 (permalink) Old Feb 10th, 10, 10:33 AM Thread Starter
Brent
67Rally's Avatar
The radiator hose connects to the intake, so it looks like it's an L98.
67Rally is offline
