What is this hole for ? - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 10th, 10, 08:26 PM Thread Starter
Greg
Getting ready to put the flywheel , clutch set and bellhousing on my engine. It is a 350 small block and will go in a 69. I think it is a 97 model block, not sure. I noticed this threaded hole on the drivers side above the oil filter ( see attach). Can anyone tell me what this is for ? Can I plug it or do I need it for something ?
69-454 is offline
post #2 of 8 (permalink) Old Feb 10th, 10, 08:30 PM
ZZ_430's Avatar
Re: What is this hole for ?
That's where the ball stud for your clutch linkage (Z-bar) goes.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 8 (permalink) Old Feb 10th, 10, 08:50 PM Thread Starter
Greg
Thanks, I should have known that, Have not done this stuff for quite a few years. Just getting back into it. Thank you.
69-454 is offline
post #4 of 8 (permalink) Old Feb 11th, 10, 06:21 AM Thread Starter
Greg
Nice picture. Another question, In your picture ,are the 2 small holes that are toward the top of the heads about one inch below the covers for a wire bracket . They are centered just above the headers ?
Thanks again..
69-454 is offline
post #5 of 8 (permalink) Old Feb 11th, 10, 06:53 AM
Rich
Its the hole that tells you that the block is worn out and no good anymore.I cost a lot of money to fix.I will help you out and give you $50 for the engine so you can start saving for a new one
RichSchmidt is offline
post #6 of 8 (permalink) Old Feb 11th, 10, 07:26 AM Thread Starter
Greg
Wow ,,,, what a nice guy your are. I think I will pass on your offer.
69-454 is offline
post #7 of 8 (permalink) Old Feb 11th, 10, 07:38 AM
ZZ_430's Avatar
Thanks again..
The factory used those blind holes on the Vortec heads to mount various things like heat shields and brackets. Most aftermarket headers will cover those anyway, so they are not needed.
ZZ_430 is offline
post #8 of 8 (permalink) Old Feb 11th, 10, 07:44 AM Thread Starter
Greg
Thanks again. I appreciate your help.
69-454 is offline
