help with pertronix ignition - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 11th, 10, 09:55 AM Thread Starter
gary
hi everyone im going to install the pertronix part#1181 in my 327 2bbl engine withflame thrower#40001,is it hard to do and do i have to redo my timing.any help would be greatly appeciated thanks gary
Real canadian67 is offline
post #2 of 2 (permalink) Old Feb 11th, 10, 10:10 AM
Doug
Re: help with pertronix ignition
No not too hard to do. You will want to pull the distributor out. I had to shim my pertronix
unit some so this makes it a lot easier to do. Yes you will have to re-time your engine. With the higher volt coil you need a key on constant 12 volts to the coil. It was a lot easier on Mustang with the distributor on the front. Not a bad job though.
Mr. Super Sport is offline
