Oil pressure,problem? - Team Camaro Tech
post #1 of 27 (permalink) Old Feb 12th, 10, 04:08 PM Thread Starter
sako
I noticed today my oil pressure was about 50-60 at idle and dropped down to 10 on the freeway. What the heck is going on? It used to be around 40-50 on the freeway. The thing is that the pressure goes up at lower rpms.
Whats going on with my engine?
Could it be my oil? im using a 5-40 synthetic oil.
I feel like I am sitting on a time bomb.
1969 SS camaro,emerald green with white hockey stripe.383 stroker with weiand supercharger.12 bolt 373 gears. 4 speed.
sako is offline
post #2 of 27 (permalink) Old Feb 12th, 10, 04:55 PM
Skip
Skeeter55's Avatar
Re: oil pressure,problem?
Man i dono.... But what you can do is pull a valve cover off and fire it up and look at how much oil gets pushed up threw the pushrods... Also try another gauge if possible. Could be bearing clearance, could be that the oil pick up fell off. Someone will chime in and get you squared away.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 27 (permalink) Old Feb 12th, 10, 05:04 PM
Rich
Something is going on with the oil pump pickup.How long do you have to run at speed for this o happen?Can you do it with the car parked by holding it at 2500 rpm?
RichSchmidt is offline
post #4 of 27 (permalink) Old Feb 12th, 10, 05:25 PM Thread Starter
sako
Rich, i will have more details when i test it again later on tonight when i go home from work.
Also, i put my hand under the gages and noticed a little bit of oil under the oil gage. Maybe its leaking and getting some air in there.
Do you think thats why the gage is not consistent.
sako is offline
post #5 of 27 (permalink) Old Feb 12th, 10, 06:10 PM
george
Sounds like the oil pump is cavitating with rpm.Most likely due to a loose or seperated oil pump pickup tube.
Without a pickup close to the oil pan floor..the pump will start to create a vortex like a flushing toilet and introduce air into the oil.At idle rpm..the vortex effect is lessened and pressure returns.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #6 of 27 (permalink) Old Feb 12th, 10, 07:44 PM
Sounds silly I am sure, but have you checked your oil level?
69 Pace Car and 69 Hard top
srode is offline
post #7 of 27 (permalink) Old Feb 13th, 10, 12:02 AM
I had this problem before to make long story short oil pump pickup fell off and was laying in my oli pan.
msicks is offline
post #8 of 27 (permalink) Old Feb 13th, 10, 03:45 AM
Howard
You may want to drain the oil pan and use an 1/8"thick wire or rod about 15" long in the drain plug hole to see if you can move the oil pick-up tube/screen that may be laying in the bottom of the pan from falling off the oil pump.If so,need to pull the engine to get the pan off to correct.Have the pick-up tube welded to the oil pump.The bottom of the screen housing should be 1/4"-5/16" from the bottom of the pan.You can use modeling clay/playdough wrapped in cellophane to determine thickness.
Just Having fun with all My Big Block Toys!!!
bbmusclecars427 is offline
post #9 of 27 (permalink) Old Feb 13th, 10, 07:48 AM
Rich
You dont usually have to pull the engine to get the pan off.You can jack te engine up off the mounts,and put a block or two of wood between the mounts ad he frame to hold it up.You need to rotate the crank to a certain position{I think the timing mark on the balancer needs to be at 5 O'Clock).Then the pan drops right out of any GM V8 car ever made.I have put rod bearings in many smallbocks with the enine in the car,so an oil pump is a no brainer.I will be doing this s weekend on he 400 smallblock in my 70 Camaro wit a big kickout pan.The pan and pump are full of milkshake from 2 cracked heads.I replaced the heads and will be dropping the pan beause the engine ost oil prssure when the oil became soft serve ice cream on a cold day.
post #10 of 27 (permalink) Old Feb 13th, 10, 09:12 AM
Try a new oil filter first, rule out the simple things before you dive in.
BrewHog55 is offline
post #11 of 27 (permalink) Old Feb 13th, 10, 09:18 AM
Rich
Very true Brewhog
post #12 of 27 (permalink) Old Feb 13th, 10, 10:36 AM
Fred
This sure brings back memories. It's THE reason to buy a shop crane and pull the engine.
128.79mph 1.428 60'
Fred Ficarra is offline
post #13 of 27 (permalink) Old Feb 14th, 10, 01:55 AM Thread Starter
sako
Re: Oil pressure,problem?
Holy **** guys, Friday night was the worst day ever. Where do i start.
Ok, after work i jumped into the Camaro and started up, the oil pressure was at 45 at cold start. Once the engine was warmed up it dropped down to 30. Took off home, on the road at 2000-2500 rpm the pressure was up and down from 20-45. Drove about 4 miles then i started to hear some rateling noise from the engine and drove to the nearest gas station to pull into. The car starts and drives but when i press the gas the noise gets louder as i go faster.
Sounds like something took a **** in my engine, what could it be?
Called the tow truck to tow it home. The driver tries to put it on the flat bed and when the chain stretched to winch the car up, it snapped my front spoiler in half. This is where i lost it and almost killed the guy. Called the company and the guy was cool and told me he would take care of it. And towed the car to my house for free.
I know should of not driven the car, but i thought i would make it home with out and major problems. Boy was i wrong.
Any ways, what do you think hapend to my engine...?
Should i start looking around for a cherry picker?
I have never pulled an engine before and might need a lot of help from you guys. I will keep you posted.
OK, now you can start telling me how much i F$#%#ED up.
sako is offline
post #14 of 27 (permalink) Old Feb 14th, 10, 07:34 AM
Tim
77wolf10.85's Avatar
aw, we've all let the smoke out of something or worked on smoked stuff that was at some point intact and giving us clues. That's how we learn the signs sometimes.
pull your oil filter and dump it across the palm of your hand. If it has 'sparklies' in it that make you want to puke just screw it back on the engine and let us know. Maybe take a pic of the oil that comes out of the filter first and post it.
Tim Smith
77wolf10.85 is offline
post #15 of 27 (permalink) Old Feb 14th, 10, 08:37 AM
Rich
If you were lucky the noise was the lifters bleeding down and when the oil pressure comes back the noise will go away.Worst case it is rod bearing noise,and you may need to rebuild the engine.If the rod bearings go to the point that they were making noise,there is little chance you will be able to just swap in some new ones,but if you pull the pan off to check the oil pump and the rod bearings are a litte iscolored what do you have to loose by swapping in a fresh set?
