Oil leak from Head Gasket? - Team Camaro Tech
post #1 of 34 (permalink) Old Feb 12th, 10, 10:05 PM Thread Starter
This is on my new 383 stroker. Is it possible for oil to leak from the head gasket? I did not think so but I have a leak and it looks like it is seeping from the passenger side head gasket towards the front of the engine. I have had a small leak for a awhile and have not been able to find where it is coming from. I was thinking it is the pan gasket but after using a leak test kit with UV dye I find that it is not. After cleaning all of the oil off of the engine and using the dye I can see that it starts to seep a small amount out of the passenger side head gasket area towards the front of the engine when the engine is running . Then it eventually proceeds all the way down the head gasket area to the rear of the head. Then runs down the block between the starter and block area and eventually ends up at the rear passenger side oil pan gasket area. I have checked everywhere to see if it is coming from somewhere else first, like the valve cover, but I can only see it starting right at the head gasket? Any ideas where it could be coming from? If it is from the head gasket what can I do to fix it, should I just retorque the head bolts? Thanks
1969 Camaro SS
Black Z is offline
post #2 of 34 (permalink) Old Feb 12th, 10, 11:27 PM
Re: Oil leak from Head Gasket?
Yea, it can leak oil from the head gasket. I'd try re-torquing the head bolts, but sounds like it's time for a new set of gaskets.
buenymayor is offline
post #3 of 34 (permalink) Old Feb 13th, 10, 12:41 AM Thread Starter
Its a brand new felpro head gasket, should not be bad on a new engine. How should I go about retorquing the head? Should I loosen them all and then go through the torque sequence? Or just retorque each bolt without loosening them again?
1969 Camaro SS
Black Z is offline
post #4 of 34 (permalink) Old Feb 13th, 10, 05:33 AM
Are you totally sure is's not from the corner of the intake??
john68 is offline
post #5 of 34 (permalink) Old Feb 13th, 10, 05:51 AM
There are no oil passages through the head gasket, so if you have oil leaking out the head gasket you have more problems than just the gasket.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #6 of 34 (permalink) Old Feb 13th, 10, 09:03 AM
dave
make sure there is thread sealant on head bolts....ran across that problem a few times
80 z-28 with a big block....someday i will finish.[sigh] someday
daves80z28 is offline
post #7 of 34 (permalink) Old Feb 13th, 10, 11:13 AM Thread Starter
So do I just start pulling one bolt at a time to verify there is sealant on them?
1969 Camaro SS
Black Z is offline
post #8 of 34 (permalink) Old Feb 13th, 10, 11:27 AM
Michael Gekko
No, don't do that. Recheck the intake gaskets, particularly the seal at the front of the block.
Eleanor's Nemesis is offline
post #9 of 34 (permalink) Old Feb 13th, 10, 11:29 AM Thread Starter
It is not from the intake, there is no UV dye in any area of the intake. It only starts at the headgasket at the passenger side right corner closest to the header flange.
1969 Camaro SS
Black Z is offline
post #10 of 34 (permalink) Old Feb 13th, 10, 01:04 PM
dave
you need to pull the top half of engine apart anyway, thread sealant on head bolts is where id pay my attention to,but without seeing its really hard to tell
post #11 of 34 (permalink) Old Feb 13th, 10, 01:07 PM
dave
just because its new, doesnt mean its perfect. it is a mass produced part
post #12 of 34 (permalink) Old Feb 13th, 10, 05:36 PM
JohnZ's Avatar
Originally Posted by onovakind67 View Post
There are no oil passages through the head gasket.
Yes, there are - the oil drainback passages go through both ends of the head gasket (but that oil isn't under pressure). Can't imagine drainback oil leaking through a head gasket unless the gasket or deck surface is damaged.
JohnZ
CRG
JohnZ is offline
post #13 of 34 (permalink) Old Feb 13th, 10, 09:44 PM
john
wagonman's Avatar
Or from a valve cover?
Clean oil can travel downward without detection.then it is noticable once it picks up a little more color from contaminants.
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #14 of 34 (permalink) Old Feb 13th, 10, 10:00 PM Thread Starter
I removed the alternator to get a better look. Here are pictures so you can see exactly where it is coming from. You can see where the oil with UV dye(green color) is seeping out from the head gasket. Before anyone one says that is looks more like antifreeze because it is green, it not. That is the UV dye. It is not coming from any area of the intake or valve cover, there is only oil coming from this spot.
1969 Camaro SS
Black Z is offline
post #15 of 34 (permalink) Old Feb 13th, 10, 10:18 PM
AJ
Was the block decked?
Were the heads checked for straightness/milled?
Is that a shim steel head gasket?
You are supposed to re torque the head bolts after the first few initial heat cycles.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
