82 350 - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 13th, 10, 01:07 PM Thread Starter
corey
82 350
hey all I took you edvice snd bought a 670 cfm street avenger, I was just wondering a couple things how can you tell if your distibutor is one tooth out .and about around what temp should the engine be running at when its warmed up it got a 270 comp cam edlebrock intake
steps350 is offline
post #2 of 9 (permalink) Old Feb 13th, 10, 05:26 PM Thread Starter
corey
Re: 82 350
anyone?
steps350 is offline
post #3 of 9 (permalink) Old Feb 13th, 10, 05:44 PM
JohnZ's Avatar
Re: 82 350
If the distributor is one tooth off, the vacuum advance can will probably hit either the #8 intake runner or the plug wire support when you go to set the initial timing, assuming the wires are correctly indexed in the cap. If it's off a tooth, just re-stab it one tooth over. Photo below shows the correct distributor position and wire indexing in the cap.
It should run around 180*-190*F if the cooling system is functioning properly.
JohnZ
CRG
JohnZ is offline
post #4 of 9 (permalink) Old Feb 14th, 10, 12:25 AM Thread Starter
corey
Re: 82 350
hey just wondering , my vacumme reads 13psi I leaned out the holly as much as I could but its still running really rich ,any ideas , its idles ok but seems to bog really bad when you try to idle up and a bit of black smoke comes out the tail pump, could my fuel pressure be to high I got a 270 comp cam and performer intake. the car ran fine before I switched out the cam and intake any ideas? need help bad
steps350 is offline
post #5 of 9 (permalink) Old Feb 14th, 10, 11:52 AM Thread Starter
corey
Re: 82 350
anyone ? could my cam be out of time?
steps350 is offline
post #6 of 9 (permalink) Old Feb 14th, 10, 12:02 PM
Smile Re: 82 350
It could be many things. Start by setting your idle transfer slots and go from there. Yo u need to remove the carburetor and view this from the bottom.
TJS69 is offline
post #7 of 9 (permalink) Old Feb 14th, 10, 12:06 PM
Smile Re: 82 350
TJS69 is offline
post #8 of 9 (permalink) Old Feb 14th, 10, 12:14 PM
Smile Re: 82 350
Set the transfer slot so that it looks like a square with the throttle blades closed. Make sure that it doesn't look rectangular.
You have too much of the transfer slot showing, and it will not run on the carburetors idle circuit.
TJS69 is offline
post #9 of 9 (permalink) Old Feb 15th, 10, 11:04 PM Thread Starter
corey
Re: 82 350
hey thanks for all the info It turned out that my choke wire was burnt and was shorting out , Sorry for all the questions but I have one more , My car is a 2dr 1982 olds cutlass, with a chevy 350 in it the 350 is a crate and has a well you no the holly a comp cam and edlebrock performer intake .I was just wondering what all wires had to be hooked up . like I got wires running to relays on the heater box were the AC use to be ant to relays under my dash by the glove box . I just want to clean it up a bit thanks in advance
steps350 is offline
