Canister Filter on Gen VI BBC - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 13th, 10, 02:03 PM Thread Starter
Robbie
All,
Can a Canister type filter system (Canister/PF 141 filter) be made to work on a Gen VI BBC? From my research, the mounting boss for the filter looks to be different on the Gen VI block. I am putting a Gen VI (ZZ454) in a 1967 Camaro and would like to keep utilizing my old trusty Canister.
Rob
Gyrine is offline
post #2 of 5 (permalink) Old Feb 13th, 10, 03:27 PM
Todd
Re: Canister Filter on Gen VI BBC
I doubt it, it's a completely different setup than gen iv. The oil filter stud screws into the block. The bypass is pressed into the block instead of being in the housing as well.
Vegas69 is offline
post #3 of 5 (permalink) Old Feb 13th, 10, 03:36 PM
And different threads in the block!!
john68 is offline
post #4 of 5 (permalink) Old Feb 13th, 10, 08:29 PM Thread Starter
Robbie
Thanks, that's what i figured
Gyrine is offline
post #5 of 5 (permalink) Old Feb 13th, 10, 08:52 PM
AJ
You can run something similar to the old school canister type, both of my cousins dragsters have these http://www.summitracing.com/parts/SOF-209-512561/Which you can remove the canister, inspect, clean filter, and re install. I'm sure you can find one cheaper one cause $164 is alot of dough for that set up, I just posted the link so you could get an idea of what I'm talking about.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
