What is so special about this 5583 metering block I have???? - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 13th, 10, 02:49 PM Thread Starter
Alright guys.......As a Holley guy, I am always getting asked if I have any 5583 metering blocks. How funny is this: I opened up a box of junk Holley parts a guy gave me for just about nothing and here is one of those darn blocks. What the heck does this go to and why are so many looking for it? Thanks!
P.S. There is another block in there with a 4519! ;o)
".......do I hear 50k....50k....now 60K............."
I think I've been watching too much Barrett Jackson!
dubs68camaro is offline
post #2 of 6 (permalink) Old Feb 13th, 10, 04:12 PM
Al Smith
Send a message via AIM to The Big Al
Re: What is so special about this 5583 metering block I have????
For Camaro is the original metering block found on OEM Holley list 4056 carbs. It is a primary metering block.
the replacement carbs never had this metering block. It was only avaiable n OEM carbs for 1968/69 model year.
It can be found on some other OEM only carbs. Never was avaiable with repalacement carbs, not even Holley carbs from GM parts.
FYI
“The bitterness of poor quality & service remains long after the sweetness of low price is forgotten”
The Big Al is offline
post #3 of 6 (permalink) Old Feb 13th, 10, 05:30 PM Thread Starter
next question.....the little post to align the bowl (there are 5 or 6 of them) is broken between the jets. Doesn't hurt performance but does it kill its OEM value???
post #4 of 6 (permalink) Old Feb 13th, 10, 07:27 PM
Bryon
bcm66's Avatar
What is a fair price (buying) for one of the 5583 metering blocks?
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #5 of 6 (permalink) Old Feb 13th, 10, 07:43 PM
Al Smith
Hard to say. This is what keeps the gasket in place
post #6 of 6 (permalink) Old Feb 13th, 10, 09:08 PM
Eric
The 5583 was used only on the 4053 and 4346 carbs on the primary side. The 4519 was used on about a dozen different carbs on the secondary side only.
The broken alignment pin between the jets isn't going to cause any problems, the rest of the pins will more than suffice to keep the gasket aligned.
Carburetor Rebuild & Restoration
Engine & Driveline Parts & Services
Vintage Musclecar is offline
