Headers for AFR 195 angle plugs - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 15th, 10, 06:31 PM Thread Starter
Jake
Hello people
I have a dart little M 406 with afr 195 angle plug heads. I am looking for a
set of headers. It is in a 69 camaro with power stering. I have 302/350
frame pads with solid mounts. I want coated ones perforably hookers. does anyone have suggestion? I do not want to have to dimple or alter.
THANK YOU JAKE
Jake 69 is offline
post #2 of 7 (permalink) Old Feb 15th, 10, 07:02 PM
Re: Headers for afr 195 angle plugs
Originally Posted by Jake 69 View Post
Hello people
THANK YOU JAKE
There's a bunch of threads on header fit - from what I have read the Dynatec's are the best bet, and they come coated.
69 Pace Car and 69 Hard top
srode is offline
post #3 of 7 (permalink) Old Feb 15th, 10, 07:57 PM
Jeremiah
My standard hookers fit good with angle plug heads, you need more than 1 5/8" primarys with your combo though.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #4 of 7 (permalink) Old Feb 15th, 10, 09:31 PM
Look at the headers from Racetech Distributors - modified version from S&S. Several members of TC run them. 1 3/4 primary, great clearance on a lowered car.
larry ford is offline
post #5 of 7 (permalink) Old Feb 15th, 10, 09:32 PM
Doug's D-368's Stick or automatic? 368's work great with a stick. Not sure about an auto.
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #6 of 7 (permalink) Old Feb 15th, 10, 10:20 PM
Andy
Send a message via AIM to 67SS&99SS
I have Dougs D368 on my 406 with AFR 195 angle plug heads. Nothing to changing the plugs. I am running 327 frame stands and energy suspension polyurethane engine mounts. I didn't have to dimple any header tubes.
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags
67SS&99SS is offline
post #7 of 7 (permalink) Old Feb 16th, 10, 06:35 AM
Re: Headers for AFR 195 angle plugs
I have Dyna Tech headers with 302 / 350 stands and energy suspenson mounts and and have no problem with plugs or steering box. I am useing the same heads on a 406
67 R/S Blue 406 518HP and 504TQ Dart block,Callies crank,Mahle pistons,Ultradyne cam 230/238 duration @.050 530 lift at 113 lsa, Afr 195 heads,Holley 4150HP carb and RPM Air gap. TKO600 with 373 gears
mike's blue67 is offline
