Replacing Carb.. - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 16th, 10, 11:29 AM Thread Starter
Ronnie
Question Replacing Carb..
I'm replacing my Edelbrock 600 carb and looking at the Holley Ultra Street Avenger 0-86770bk. This would obviously generally be an easy switch, but I've also replaced my powerglide tranny with a 700r4. Anyways, I was wondering what bracket everyone was using to connect the linkage to, what stud to get for that bracket, and what fuel line I should get. I need to replace my current fuel line anyways and want to get something that has both a filter and a pressure gage. I haven't bought the carb yet so if anyone has any suggestions otherwise let me know! I'm just trying to avoid buying the incorrect parts or wishing I had went with a different set up in hind sight.
Thanks everyone!
rons69camaro is offline
post #2 of 4 (permalink) Old Feb 16th, 10, 12:27 PM
Matt
Re: Replacing Carb..
You'll need the 20-121 bracket to achieve the proper TV cable geometry for your 700R4. The bracket mounts on to the carburetor's throttle lever. You'll also need a bracket for the TV cable itself. Do a search on here and you'll find plenty. I went with this one, works OK but I would prefer one that mounts directly to the intake.
Matt
zlek131 is offline
post #3 of 4 (permalink) Old Feb 16th, 10, 04:39 PM Thread Starter
Ronnie
Question Re: Replacing Carb..
Thanks Matt.
Has anyone tried this fuel line from Summitt?
http://www.summitracing.com/parts/SUM-G3120/
I'm looking for something that will both fit the carb well and has a pressure gage/filter. Any suggestions?
post #4 of 4 (permalink) Old Feb 17th, 10, 07:00 PM
I purchased this set (#29603) from Autozone for around $40 and it works great. I like having flexible lines as they are much easier to install.
bld22663 is offline
