TPI Question - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 16th, 10, 05:06 PM Thread Starter
Erick
TPI Question
I was wondering if you can "port" the plenum on a tpi where the throttle body bolts up to it. I'm using a bigger throttle body and those two little holes could sure be opened up a little to match the new throttle body.
erickb89z is offline
post #2 of 5 (permalink) Old Feb 16th, 10, 06:13 PM
Re: TPI Question
Of course, take it off to do it, the bottom intake is the big flow restriction tho.
john68 is offline
post #3 of 5 (permalink) Old Feb 17th, 10, 04:57 PM Thread Starter
Erick
Re: TPI Question
Doesn't Edelbrock make an aftermarket tpi setup?
post #4 of 5 (permalink) Old Feb 17th, 10, 06:04 PM
Re: TPI Question
Yes and a couple other companys also. You might want to try "firstgen.com", these
guys are very good with this stuff. Might be 'gens' plural, been a while but they are good you can read for hours.
john68 is offline
post #5 of 5 (permalink) Old Feb 18th, 10, 06:36 PM Thread Starter
Erick
Re: TPI Question
Thank you very much for your help. one more thing, do you know where the fuel pump relay is on an 89 iroc?
