Cleaning Engine for Paint with Brake Cleaner? - Team Camaro Tech
post #1 of 15 (permalink) Old Feb 17th, 10, 03:27 PM Thread Starter
Looking for something to clean a bit of assembly oil residue off block and heads before painint an engine - is Brake Cleaner a decent choice? The can I have from CRC says 'leaves no residue'. I am using spraybombs from Duplicolor - their ceramic something paint.
69 Pace Car and 69 Hard top
srode is offline
post #2 of 15 (permalink) Old Feb 17th, 10, 03:41 PM
Re: Cleaning Engine for Paint with Brake Cleaner?
To get it pre-cleaned...ok. But as a final cleaned before paint May cause fisheyes.
I would hit it clean with Brake Kleen and then a final wipe with lacquer thiner. IMO
68 Camaro~LSx ~all motor
post #3 of 15 (permalink) Old Feb 17th, 10, 04:01 PM Thread Starter
How about Acetone for the final wipe?
srode is offline
post #4 of 15 (permalink) Old Feb 17th, 10, 04:33 PM
Dean
Brake cleaner is fine for getting the worst of it off but I wipe EVERYTHING down with BASF 203 or something similar before painting.
440sixpack is offline
post #5 of 15 (permalink) Old Feb 17th, 10, 05:15 PM
AJ
lacquer thinner works awesome.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #6 of 15 (permalink) Old Feb 17th, 10, 05:36 PM
Can you use a spray gun or spray bottle for the thinner or just wipe?
1969 Camaro Convertible 427 5 Speed
provfirescott is offline
post #7 of 15 (permalink) Old Feb 17th, 10, 05:51 PM
dave
wax and grease remover paint stores or part stores carry...i found that works the best . i usually get fish eyey when using brake clean...good luck
80 z-28 with a big block....someday i will finish.[sigh] someday
daves80z28 is offline
post #8 of 15 (permalink) Old Feb 17th, 10, 06:17 PM
AJ
I just used cloth for the thinner, you have to do some wiping, I'm not sure how any paint remover would work through a spray gun, never tried it.
Get a good set of wire brushes for your drill also.
When you paint it, do 1 coat at a time and make sure it is completely dry before the next coat, too many coats especially too quickly will crack down the road.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #9 of 15 (permalink) Old Feb 17th, 10, 07:44 PM Thread Starter
Thanks, I'll stop by an automotive paint store and pick up a good cleaner before painting and use Acetone on a rag instead of the brake clean to get the assembly lubes off the block, don't need any fish-eyeing!
srode is offline
post #10 of 15 (permalink) Old Feb 17th, 10, 07:59 PM
2nd for Acetone, but have good rubber gloves as it is quite cold and evaporates fast
68rs327conv is offline
post #11 of 15 (permalink) Old Feb 17th, 10, 09:24 PM
Steiner
You can get a big bottle of Duplicolor wax and grease remover at most regular auto parts stores. I also have access to 99% isopropyl alcohol and talk about degreasing....use it without gloves and your hands look like Danish wedding cookies.
'69 Camaro
500hp/538lbft
Steiner is offline
post #12 of 15 (permalink) Old Feb 19th, 10, 04:46 AM
Gary
x3 for acetone, that's what my buddy who does custom performance coatings on guns uses. He says there's nothing else that leaves less residue and does as good of a job at cleaning.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Busted Knuckles is offline
post #13 of 15 (permalink) Old Feb 19th, 10, 04:48 AM
BILL
SPARKY69's Avatar
x2
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #14 of 15 (permalink) Old Feb 19th, 10, 04:49 AM
BILL
SPARKY69's Avatar
you said danish wedding cookies!! haha... some one has an addiction!
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #15 of 15 (permalink) Old Feb 19th, 10, 08:27 AM
Make sure that you have the proper ventilation, and air flow using that cleaning stuff. Hope ya don't smoke either! When cleaning anything...always check for silicon as already suggested.
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
captcanuck68 is offline
