Pulling an engine - Team Camaro Tech
post #1 of 17 (permalink) Old Feb 17th, 10, 07:09 PM Thread Starter
Pulling an engine
going to remove my 350 out of my 67. I want to do some engine work. Is it easier to pull the 4 speed tranny with the engine or disconnect before i pull it?
brianstevens03 is offline
post #2 of 17 (permalink) Old Feb 17th, 10, 07:34 PM
AJ
Re: pulling a engine
If you don't intend to do work to the trans, it's much easier to pull just the motor.
4 bolts to the bell housing.
Trans is alot more, remove handle, cross member, drive shaft...
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #3 of 17 (permalink) Old Feb 17th, 10, 07:48 PM
I always pull them together. It's easier (for me)
post #4 of 17 (permalink) Old Feb 17th, 10, 08:00 PM
Chris
You have to put the motor back in! You will have to pull the trans anyway. It's different
for an automatic.
hirpms is offline
post #5 of 17 (permalink) Old Feb 17th, 10, 08:51 PM
scblucam's Avatar
I have always done it together
68 302 M20 - 85 IROC Z
scblucam is offline
post #6 of 17 (permalink) Old Feb 17th, 10, 09:11 PM
AJ
I'm kind of confused at what he is asking now...
Are you wanting to pull the trans to do work?
If so, do it together.
If not, leave it be, it doesn't have to be taken out just to pull the motor...
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #7 of 17 (permalink) Old Feb 17th, 10, 09:36 PM Thread Starter
im not planning to do work on the tranny. It was what is easier to do . Both or just motor? It sounds like their are mixed opinions anyways
post #8 of 17 (permalink) Old Feb 17th, 10, 09:51 PM
Russ
rafbody's Avatar
Just pulling the engine, it is easier to leave the transmission in the car.
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
rafbody is offline
post #9 of 17 (permalink) Old Feb 17th, 10, 09:57 PM
If it's a Muncie, I'd pull the tranny before yanking the engine; if it's a Saginaw, I'd leave it on and pull them together.
Mike - '68 Camaro with lots of stuff done to it.
Mkelcy is offline
post #10 of 17 (permalink) Old Feb 17th, 10, 10:46 PM
AJ
...It's FOUR bolts in the back of the bellhousing, much less weight.
There is no way on Earth it's easier to pull them both.
4 bolts + 2 motor mount bolts, lines, wires, and it's out, no weird angles to deal with, much easier to mount on stand right away.
I would have to completely remove the headers to pull the trans and motor out in my car, or the hoist would topple over, it's not cheap, just can't extend the legs enough.
If you were doing trans work, which your not, def pull them both, working on the trans from the underside is a pain.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #11 of 17 (permalink) Old Feb 17th, 10, 11:11 PM
Matt
The less parts you take out the less parts you got to put back in, especially if they're big and there is no reason to pull them. But then again, those two top bell-housing bolts can be a [email protected]$#%... I recently pulled the motor and also needed to pull the trans. I went the separate route. If you do decide to pull both as one, make sure you get an engine load leveler as it makes a world of difference.
Matt
zlek131 is offline
post #12 of 17 (permalink) Old Feb 17th, 10, 11:25 PM
Todd
I like to intall the engine with the bellhousing, clutch, and accessories all installed. That leaves me about an inch on both sides. It goes in nice and level and keeps things in alignment so I don't scratch my pretty firewall or oil pan. Stabbing a tranny isn't that bad if you have a good alignment tool and real input shaft. Eight bolts and your tranny is in and supported.
Vegas69 is offline
post #13 of 17 (permalink) Old Feb 18th, 10, 06:35 AM
Chris
Re: Pulling an engine
I would pull the tranny first. I would not want to take a chanch of hitting the input shaft.
Then pull the motor, bellhousing and all. Then back in the oposite way. Tranny last.
It will be easier to do it that way, especially if you end up doing it yourself. If you pull the engine and tranny together, you have to raise the car pretty darn high, and you need help doing it. Especially going back in.
hirpms is offline
post #14 of 17 (permalink) Old Feb 18th, 10, 06:55 AM
123
tom
pulled mine out in one piece but i'm just storin it away
123 is offline
post #15 of 17 (permalink) Old Feb 18th, 10, 10:12 AM
I'd pull the transmission first - Like others said, it's 4 bolts to disconnect from the bellhousing - very easy to do and makes manuvering the engine easier
69 Pace Car and 69 Hard top
srode is offline
