SBC gas in oil - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 18th, 10, 05:34 PM Thread Starter
Pat
Exclamation SBC gas in oil
I recently changed intake gasket because of an anti freeze leak near the dist.I also changed the fuel pump block off (new 1,been elec. pump since I bought it)and noticed it smelled like gas.I pull the dipstick and I am pretty sure I can smell gas in the oil.What steps should I take to trouble shoot?I'm thinking a head gasket.Thanks for any input ahead of time...Pat
CAJUN68 is offline
post #2 of 8 (permalink) Old Feb 18th, 10, 05:50 PM
gary
Re: SBC gas in oil
My guess would be running too rich, washing down cylinder walls. Is this carb or inj.?
pro70z28 is offline
post #3 of 8 (permalink) Old Feb 18th, 10, 06:10 PM Thread Starter
Pat
Re: SBC gas in oil
I haven't started her up since,but I did change carbs and ran it once in the garage after.It was runnin rich,I'm no motor head,but what you're tellin me could be the problem.Cam info suggests a 850 cfm which I have,not sure on jet size...what max. fuel pressure should I be seeing?(holley carb)
CAJUN68 is offline
post #4 of 8 (permalink) Old Feb 18th, 10, 06:15 PM
gary
Re: SBC gas in oil
It's been awhile but I think the fuel PSI should be around 6-7 Lbs. Somebody will verify I'm sure. If you do have gas in the oil I'd change it. Bad for bearings and a little dangerous if there is enough gas in the crankcase.
pro70z28 is offline
post #5 of 8 (permalink) Old Feb 18th, 10, 06:18 PM Thread Starter
Pat
Re: SBC gas in oil
I haven't run it since and will definately be changin the oil.Thank you for your thoughts...
CAJUN68 is offline
post #6 of 8 (permalink) Old Feb 18th, 10, 06:19 PM
Bill
Re: SBC gas in oil
Pat,
If you have been running the engine in the garage a lot without really getting it up to operating temperature, it is pretty common to smell some fuel in the oil. Really obvious when you run Cam2 or other leaded racing fuels.
Also, like the others have said, if it is running real rich it will definitely get that way.
The head gaskets have no bearing on this at all.
If you are not going to drive it, dont start it
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #7 of 8 (permalink) Old Feb 18th, 10, 06:50 PM Thread Starter
Pat
Re: SBC gas in oil
Bill,I have run it a hand full of times with out letting it get to temps when I got it home.I had no fuel press. in the begining and found that the fuel filter was clogged(looked like someone had took a crap in it)and also the return line from the reg. was way to small according to manufacturer so i got that square to.It's my first hot rod(1st car period,always drove trucks,work trucks)and does not have to be run at all,atleast till I get her square.My fuel press. is set at 6 psi.I'm thinking I need a carb adj. along with allowing the motor to reach operating temps?It's a pump gas motor.Not verified yet but it's supposed to be a 10/1 comp.Thanks for any any and all advise.
CAJUN68 is offline
post #8 of 8 (permalink) Old Feb 18th, 10, 07:44 PM
Ron
Re: SBC gas in oil
It is also possible that there is an internal leak in the fuel pump that is leaking gas back into the engine case.
This was my 70 1/2 Z28
Z15CAM is offline
