March serpentine system - Team Camaro Tech
post #1 of 30 (permalink) Old Feb 19th, 10, 05:21 AM Thread Starter
I am thinking of going with the March serpentine system on my 383 small block, has anybody use's there setup and how did it work and did all the belt's line up, or is there a better set up March what's about 700 for everything Thank's Jim
jcrich54 is offline
post #2 of 30 (permalink) Old Feb 19th, 10, 05:24 AM
BILL
SPARKY69's Avatar
Re: March serpentine system
Check into zoops.com for another option!
http://www.zoops.com/home.asp
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #3 of 30 (permalink) Old Feb 19th, 10, 05:26 AM
BILL
SPARKY69's Avatar
Ive used both zoops and the march set ups and have had no problems with either one!!
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #4 of 30 (permalink) Old Feb 19th, 10, 05:53 AM Thread Starter
Thanks Bill I will check out Zoops system
jcrich54 is offline
post #5 of 30 (permalink) Old Feb 19th, 10, 09:21 AM
Frank
We sell and install a lof of these systems. We have the mid mount system on Michaels Monte Carlo on our website which is a 6500 RPM 383. No belt issues.
We also have a 69 Camaro with a 383 and a Style trac and it works perfectly also.
Feel free to call with any questions
ProdigyCustoms is offline
post #6 of 30 (permalink) Old Feb 19th, 10, 09:38 AM
foreverlookin's Avatar
Not to hi-jack this thread but I will ask has anyone used the March 655-22072 with A/C? I am thinking about buying it as it seems best value for my needs.
http://www.summitracing.com/parts/MCH-22072/
foreverlookin is offline
post #7 of 30 (permalink) Old Feb 19th, 10, 10:12 AM Thread Starter
That is the set up I just ordered today from Smmit I just have to put my AC compressor on the passinger side with is better, no hoses running over the top of my motor, it will be hear tue. or wed. and I order the hard lines from Vintage Air and they are exchanging the compressor with a serpentine one, I will let you now how it works out
jcrich54 is offline
post #8 of 30 (permalink) Old Feb 19th, 10, 11:11 AM
Jim, I would really like to know how things go for you as I am going to be ordering my stuff very shortly and it sounds like I am doing the exact same thing you are.
post #9 of 30 (permalink) Old Feb 19th, 10, 12:32 PM Thread Starter
Steve I will let you know how it works out
jcrich54 is offline
post #10 of 30 (permalink) Old Feb 19th, 10, 02:17 PM
John Doe
i was so tired of my alt sitting cockeyed with the after market alt bracket the sat over the #1 header. i broke many of them and the belt was never straight and didnt last long.
i decided to dump my ac. i moved my alt to the pass side. i installed a long shaft water pump and the march kit.
i love the mid mount set up. it was worth every penny.
Bucknaked Racing is offline
post #11 of 30 (permalink) Old Feb 19th, 10, 02:31 PM
Trev
madcarson's Avatar
My MARCH system with ac looks and works fine on my 383 ! I have to build my own lines but no big deal.
69 Resto MOD
383
madcarson is offline
post #12 of 30 (permalink) Old Feb 19th, 10, 02:41 PM
TC
If you are doing a show car and want perfection, definitly don't go with March IMO. I went thru 4 sets trying to get something that was not nicked, a decent polish, etc and the quality was subpar. I spoke with them and they said that what I was getting is usuall.
I got fet up and tried Billet Specialties and still had do 2 sets for a perfect set. However, the polish and percision was so much better. Again this was my experience and my 2 cents.
I've heard great things about Zoops and that was next on my list if BS didn't work out.
1968 Camaro RS orig AC car, ZZ Fatburn, Doug's D368 Headers, Tremec TKO600 w/ Hurst Blackjack, 12 Bolt Posi 3:73 mulitleaf, SFC's, Budniks, Hotchkis, Magnaflow, etc
6Z8RS is offline
post #13 of 30 (permalink) Old Feb 19th, 10, 05:29 PM
Frank
We have the 22072 and big brother 23072 mid mount systems on a couple of our own cars
Small Block in Michaels Monte Carlo
All Aluminum 572 Big Block Mid Mount Kit
post #14 of 30 (permalink) Old Feb 19th, 10, 07:50 PM
Very nice Frank!
By the way the frame connectors worked out great!
post #15 of 30 (permalink) Old Feb 19th, 10, 08:46 PM
Kurt
camsdad's Avatar
Here's mine.
I did have to shim up the PS to get it to align up straight with the crank pulley.
Also, I have a Holly HP fuel pump and hard fuel line up to the fuel filter that challenged me for clearance around the back of the A/C compressor & bracket.
I agree with 6Z8rs. Mine also has a couple of nicks and scratches. Right out of the well packed box. 2 on the lower Alt bracket and 1 on the upper pulley. The finish was good.
Keep in mind it is aluminum which is a soft metal. But I do agree that the quality control for perfection and bragging rights needs improvement at March.
Kurt
1969RS 14yrs into it.
383CID Lives
200R4 Trans, 3:42 Posi 12 Bolt Ready
Cold ones in the fridge. Dam, there gone. BRB
Getting closer to my goal.
camsdad is offline
