86 makeover - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 19th, 10, 10:32 AM Thread Starter
86 makeover
I have an 86 camaro that came with a 2.8L v6. About a year and a half ago the engine blew. I want to put a 350 carburated model in it but im not sure what kind of upgrades the car would need. Will the 350 bolt to the existing tranny? Will i need to replace the current rear end? And will there be a need to change out the radiator? Any input would be much appreciated.
cdm369 is offline
post #2 of 5 (permalink) Old Feb 19th, 10, 11:09 AM
Jeremy
Re: 86 makeover
Your tranny will not work. It may bolt up, but won`t last long. The rearend doesn`t have to be changed, but the factory rearend is weak. The radiator will have to be upgraded as well. You`ll need new motor mounts, but can`t really think of anything else that would need to be changed to make work.
67 Camaro
makoshark is offline
post #3 of 5 (permalink) Old Feb 19th, 10, 11:49 AM
Jess
Re: 86 makeover
Tranny wont work and the rear end will explode if making good power. You will need better cooling fans and radiator... Jeremy is right!
Jess67
67 Camaro Blue 427, 4-speed, 12 bolt
67 Camaro 350, 200-4R, PS, AC, PB, IN PARTS
Jess67 is offline
post #4 of 5 (permalink) Old Feb 19th, 10, 12:03 PM
BILL
SPARKY69's Avatar
Re: 86 makeover
welcome to team camaro!!
as the aboves stated
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #5 of 5 (permalink) Old Feb 19th, 10, 12:53 PM
Re: 86 makeover
The 2.8 is fuel injected, wireing will not work with 350.
john68 is offline
Tags
3rd generation, engine swap, overhal, restoration
