Crankshaft threads for balancer stripped!!! - Team Camaro Tech
post #1 of 18 (permalink) Old Feb 20th, 10, 03:59 PM Thread Starter
What would be the best method to repair the threads in my crankshaft that holds the harmonic balancer on. I was assembling my engine...turning it using the balancer bolt so I could adjust the valves and all of a sudden.....it broke loose. I just got this short block back from the machine shop with a "new" crankshaft installed. I'm sure he'll make good on the repair but I'd like to know the best method before I talk to him. I know about heli-coils, but what about drilling and tapping to the next larger size? Any ideas would be appreciated.
reelknots is offline
post #2 of 18 (permalink) Old Feb 20th, 10, 04:48 PM
Todd
Re: Crankshaft threads for balancer stripped!!!
It's not the engine builders fault. Your really not supposed to turn the engine by the balancer bolt. We've all done it though. You can buy a tool from Jegs or Summit that bolts on the front of the balancer. I'd just go one size larger.
Vegas69 is offline
post #3 of 18 (permalink) Old Feb 20th, 10, 06:02 PM
Bill
Steve,
I prefer a helicoil rather than going to the next size up. Like Todd said, the bolt really is not meant for turning the engine over but it really should be able to do it without stripping the threads
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #4 of 18 (permalink) Old Feb 20th, 10, 06:31 PM
Todd
Here is the tool I was referring to. http://www.jegs.com/i/JEGS/555/80743/10002/-1
Vegas69 is offline
post #5 of 18 (permalink) Old Feb 20th, 10, 06:39 PM
Chad
67 Plum's Avatar
Why the helicoil over a larger bolt?
67 Plum is offline
post #6 of 18 (permalink) Old Feb 20th, 10, 06:48 PM
Heli-coil is said to be stronger than the threads that were there to begin with.
68 Camaro~LSx ~all motor
post #7 of 18 (permalink) Old Feb 20th, 10, 07:07 PM Thread Starter
I believe the heli-coil would be better so I can still use the normal puller and pusher to install/remove the balancer. I'm kinda miffed by the opinion to not use this bolt to rotate the crank as I've been doing this for years without incident. How do you guys rotate the crank to set up valve lash?
post #8 of 18 (permalink) Old Feb 20th, 10, 07:09 PM Thread Starter
Oh my. I just looked at the tool that Todd refered to....never knew it existed...poop.
post #9 of 18 (permalink) Old Feb 20th, 10, 07:27 PM
JohnZ's Avatar
I also use both of these, when the balancer isn't installed yet. Use the right tools and you won't damage anything.
ID:	14393   Click image for larger version
JohnZ
CRG
JohnZ is offline
post #10 of 18 (permalink) Old Feb 21st, 10, 06:09 AM
So do you have to pull the balancer every time you run the valves? That bolt is torqued to 85 ft/lbs. As long as your motor turns with less force than that you will never hurt those threads.
markw is offline
post #11 of 18 (permalink) Old Feb 21st, 10, 06:22 AM
Taking the sparkplugs out (PITA) when turning the motor by hand at the crank makes things easier too
post #12 of 18 (permalink) Old Feb 21st, 10, 07:14 AM
Paul
Not if you use the tool Todd listed; it works great. The other's work nice to, especially during the rebuild process.
Turning a fresh rebuild with a radical cam and probably with plugs in is just too risky. Using the tools saves a lot of trouble.
Paul68RS/Z28 is offline
post #13 of 18 (permalink) Old Feb 21st, 10, 07:47 AM
Does that tool stay bolted to the balancer? Looks to be counterbored for the crank bolt. Neat idea.
markw is offline
post #14 of 18 (permalink) Old Feb 21st, 10, 12:19 PM
but the heli coil is still threaded into the parent metal- which makes it as strong as a bigger bolt.. i think most small block people just drill and tap it out for a big block balancer bolt. if we are talking about a big block, then upgrade to a bolt used on any number of other engine families.
you don't plan sincerity.
novaderrik is offline
post #15 of 18 (permalink) Old Feb 21st, 10, 01:16 PM Thread Starter
Just to clarify my situation. The engine is on a stand and I did not have the spark plugs in and only half the valves were adjusted when the threads broke loose. The engine required 25 ft/lbs to turn before I even had the heads on....but I don't have any idea what a short block with new bearins and piston rings requires to turn. At any rate, I kind of agree with Mark that since the bolt is torqued to 85 ft/lbs., the threads should have held up. At any rate, you can bet in the future I'm gonna use one of the tools suggested even if I have to remove the crank pulley when it's in the car. Thank you all for your comments.
