Small base circle cam - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 20th, 10, 06:57 PM Thread Starter
Question Small base circle cam
I have recently purchased a new Crower 00903 small base circle cam (218*/226* .461/.468 112lsa) from an individual who decided to run a
different cam in his stroker engine.
My plan is to install this new cam in a new GM Goodwrench crate engine along with a set of Aluminum L98 Corvette heads that have some mild bowl work done to them.
My question is: will I have to do anything different on pushrod length since this is a small base circle cam?
Your input is appreciated.
69 Camaro Coup-My Granny's car-327/210hp
Weiand Stealth Intake/Carter 625cfm 4bbl. carb.
Pertronix Ignition
Coated Headers/2.25" dual exhaust with H-pipe/Turbo Muffs
Th350 trans. W/Transgo Shiftkit
Search TV Christian Ministry:
MarkP. is offline
post #2 of 5 (permalink) Old Feb 20th, 10, 07:26 PM
Re: Small base circle cam
Most likely yes
68 Camaro~LSx ~all motor
post #3 of 5 (permalink) Old Feb 21st, 10, 08:52 AM
I think you need lifters that are longer for a small base circle, because std. lifters would set to low in lifter bore to line up with oil passage
Riley is offline
post #4 of 5 (permalink) Old Feb 21st, 10, 10:49 AM Thread Starter
Summit usually charges $137.95 for this cam. I picked up this new cam for $65.00 to my door. Sounds like I need to get in touch with the Crower tech line and see what lifters and pushrods they recommend.
Thanks all.
Pertronix Ignition
MarkP. is offline
post #5 of 5 (permalink) Old Feb 21st, 10, 02:58 PM
I went with a small base circle cam and used my standard comp hyd rollers with it. While motor was apart I mocked cam and lifters up, looking thru the cam oil galley holes to make sure the lifter oil grove was lined up properly and it was.
When I got to the push rods, I obtained a push rod length checker to make sure the rocker arm geometry was correct, it was not. I did go to the longer push rods to correct this, using a small base circle cam. Lifters actually set lower than stock in the lifter bore.
TC # 349
zdld17 is offline
