When to replace heads bolts - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 20th, 10, 07:18 PM Thread Starter
How many times do you guys reuse your head bolts? Is there a streach guage you can get to check them?-Thanks
bautino95 is offline
post #2 of 7 (permalink) Old Feb 20th, 10, 08:09 PM
Re: When to replaced heads bolts
Maybe 2 or 3 times max and I use ARP bolts.
68 Camaro~LSx ~all motor
post #3 of 7 (permalink) Old Feb 20th, 10, 08:24 PM
Skip
Skeeter55's Avatar
ARP here to...
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #4 of 7 (permalink) Old Feb 20th, 10, 11:22 PM
Dean
How many times do you change your wheels before you put new studs in the hub? there's no reason to buy new head bolts unless there's an obvious problem with the bolt in my opinion. it's good to be cautious but sometimes it just doesn't make sense.
440sixpack is offline
post #5 of 7 (permalink) Old Feb 20th, 10, 11:26 PM
Ron
X's 2 for Iron Heads - Just Re-Torque after about an hour of run time on a re-build and if it don't, reach into your Stock Bin, ensure threads are clean and past with RTF or Permatex with lube under the head and use it; I recommend Studs with Alu-Heads.
This was my 70 1/2 Z28
Z15CAM is offline
post #6 of 7 (permalink) Old Feb 24th, 10, 01:07 PM
Re: When to replace heads bolts
NEVER, the stock SBC / BBC head bolts can be reused quite a lot, The block will be worn out before the head bolts are.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
post #7 of 7 (permalink) Old Feb 24th, 10, 02:47 PM
BILL
SPARKY69's Avatar
Originally Posted by Skeeter55 View Post
ARP here to...
X3
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
