Water pump question - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 21st, 10, 08:13 PM Thread Starter
Water pump question
I have a serpentine system form a 2002 s10 and am using the waterpump as well. My question is wheather or not the "nipples/hose connectors" screw out of the pump or are they glued in somehow? It would really help me clean up the hose routing if I could remove an d replace the stock ones. I dont want to try to remove too hard until I know that they screw out.
Jason
1968, 383, 700R4, Convertible
Southtwnr is offline
post #2 of 3 (permalink) Old Feb 22nd, 10, 04:28 AM
Re: Water pump question
I would imagine if you see threads and a hex on the nipple, then its screwed in.
Otherwise, smooth tube, it would be a press fit or cast into the pump body.
post #3 of 3 (permalink) Old Feb 22nd, 10, 07:06 AM Thread Starter
That makes sense. Its smooth so its probably pressed in. Disappointing, but Im glad I didnt try to muscle it out!
