Am I under carbed ? - Team Camaro Tech
post #1 of 13 (permalink) Old Feb 21st, 10, 11:12 PM Thread Starter
Chris
Send a message via Yahoo to cluxford
Am I under carbed ?
I have a 632 cube Tall Deck BBC.
It is a crate motor that came with a single 1050 dominator
Want old school toughness and don't mind sacrificing a few HP (dynoed at 816hp at the flywheel anyway and this is for a street car so a few less G-G's won't worry me)
Now I have a Edelbrock C-66-R and I got twin 600CFM Endura Shine Performer carbs. It's a tall deck block and no tall deck manifolds so it's running spacers between the manifold and the heads (made and sold by Edelbrock for this very purpose)
I'm no expert in carburettion but everyone who looks at the car (still being built) say the 600's are way too small.
I want polished or endura shine as it is a show car.
I've been told I should go a Holley Ultra Dominator (like a 700CFM or 750), I've also noticed that there is a Thunder Series Edelbrock in Endura shine
My questions are:
1. Which carb would you recommend (Holley Ultra or Edelbrock Thunder) - Note I am a novice on dual quads so want it to be easy tuning
2. if Holley as recommendation - can they fit a Edelbrock C-66 intake manifold - I hear they are both square bore. I've done a ton of web searches and can't get a straight answer.
Will be calling both Edelbrock and Holley tomorrow (Mon here in Oz, still only Sun there in the US), but interested in people's thoughts
Thanks in advance for the advice
cluxford is offline
post #2 of 13 (permalink) Old Feb 21st, 10, 11:18 PM
Ron
Re: Am I under carbed ?
What a MONSTER Engine - Gads! - Is it a Holiday on Monday? And I thought I had problems - LOL
This was my 70 1/2 Z28
Z15CAM is offline
post #3 of 13 (permalink) Old Feb 21st, 10, 11:27 PM
AJ
Edelbrock carbs are not the greatest for performance, and tuning can't be as accurate as a holley in my opinion.
I would def. go with a holley based carb.
There are alot of brands based off of holley that are very pretty, and expensive.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #4 of 13 (permalink) Old Feb 22nd, 10, 03:46 AM
Beings its a street/show car I think you'll be fine with 2 x 600's.
I do not like Edel. Carbs but thats me...
68 Camaro~LSx ~all motor
post #5 of 13 (permalink) Old Feb 22nd, 10, 11:00 AM
Mickey
Moonpie's Avatar
No offense, but if it is a show car why does it matter what carbs are on it? Just curious.
Moonpie is offline
post #6 of 13 (permalink) Old Feb 22nd, 10, 03:35 PM Thread Starter
Chris
No offence taken, will be shown for 1st year then driven hard, real hard
cluxford is offline
post #7 of 13 (permalink) Old Feb 22nd, 10, 04:51 PM
Chad
67 Plum's Avatar
My math says 2 X 600 = 1200?
67 Plum is offline
post #8 of 13 (permalink) Old Feb 22nd, 10, 06:30 PM
george
Year one..run the eddy 2x4 setup for the car shows.
Year two..ditch the bling bling and reinstall the dom atop a Weiand Team G.Part#7624 for tall decks.You did say you want to pound on it..dont let a tiny 540 spank your 632.
Was a time not long ago..that 454 cid ruled.Now here i am calling a 540 tiny.My,how the times are changing.In a good way though.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #9 of 13 (permalink) Old Feb 22nd, 10, 06:44 PM
Rich
Dont worry about what the tirekickers are saying.You will need to calibrate any carbs you choose to work with the tunnel ram,but you dont need giant carbs to make the power your engine dyno'ed at.If you want the big carb look try adding a secondary metering block and center hung float bowls to your existing carbs.They will look just a big as any tricked out 950,but still be only 600.You can buy the float bowls in the shiny finish,but I am not sure about the metering block kit.Good luck.
RichSchmidt is offline
post #10 of 13 (permalink) Old Feb 22nd, 10, 06:55 PM Thread Starter
Chris
Thanks all for the advice, I spoke with Edelbrock today and I am all good.
Issue ain't the carbs, it's the low rise dual quad manifold. It just isn't going to provide enough flow at high RPM's
Good news is even with the high rise single plane and 1050 Dominator engine made 816Hp and 825 ft/lbs at 4300 peak
So while I know I will lose some Hp, Edelbrock tell me that the low rise dual quad is good to 5000 rpm and dual 600's are plenty big enough
Hey if it drops to 750 Hp it will still be enough to scare the crap out of me on the street
When I go racing I'll probably just bite the bullet and go blown / injected. Then no 540 will touch me anyway
cluxford is offline
post #11 of 13 (permalink) Old Feb 22nd, 10, 08:22 PM
Rich
You might want to look into having that low rise intake ported.It may never come up to the level of the race intake and dominator,but if you are paying the price for running a hot engine already(rough idle,somewhat poor street manners} why not get your money's worth out of it?I dont know much about the intake you are choosing but here is some advice.Make sure it is ported to match the heads,if there is a plenum divider under each carb remove it,and if you have room for a 1" tapered spacer under each carb then do it.
post #12 of 13 (permalink) Old Feb 22nd, 10, 08:30 PM
Jeremiah
Im with Ace's68.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #13 of 13 (permalink) Old Feb 23rd, 10, 12:21 AM
AJ
They will tell you anything to sell a product.
The guys here will tell you straight up.
But I see your point on not caring about max power, everyone is different.
Here is a link to a pretty carb that will perform and in my opinion looks better than any edelbrock, it's based off of holley:
http://www.summitracing.com/parts/QFT-Q-750/?rtype=10
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
