383 Needs harmonic balancer. which one? - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 22nd, 10, 06:35 AM Thread Starter
383 was balance with fly wheel and balancer what to replace with new balancer.Motor out of car right now on stand what can I use.Do i have to have it rebalanced?Trying not to pull it a part.Just and old 400 balancer would like a new.Not a race car but I do get on it and dont want to hurt the motor with a cheap one.Do they make a 0 balance one that I can add and be done with it.
FastFred is offline
post #2 of 6 (permalink) Old Feb 22nd, 10, 03:58 PM
Re: 383 Needs harmonic balancer witch one
Fred, if you motor was balanced with this kit, it has to stay with the motor. I have never heard anyone swapping out later with a differant balancer. Might want to look at the balancer to see if any weight was taken out of it. My thinking is this was a kit? If its not a race car, dont see what the matching balancer would hurt. Maybe someone esle will chime in here.
TC # 349
zdld17 is offline
post #3 of 6 (permalink) Old Feb 22nd, 10, 07:50 PM
JohnZ's Avatar
Only if the 383 was internally-balanced with zero-balanced flywheel and balancer when it was built.
JohnZ
CRG
JohnZ is offline
post #4 of 6 (permalink) Old Feb 22nd, 10, 10:53 PM
Sean
You need to know if internally or externally balnced, but since you say "just an old 400 balancer" I would guess external. If the balancer was not modified when the motor was balanced you can just get another balancer for either a 400 or one thats 0 balanced for internally balanced assembly. Usually shops won't remove metal from the balancer during balancing, but you want to be sure.
If you can figure out what you have Pioneer makes a real nice replacement balancer, affordable too.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #5 of 6 (permalink) Old Feb 22nd, 10, 11:40 PM
Steiner
Look on the back side of your current balancer to see if it has a weight on it or and/or some holes drilled in it. If the weight is there it's an external balance. You should be able to purchase another one and take both to a competent shop where they can match the new one up with the old one.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 6 (permalink) Old Feb 23rd, 10, 06:14 AM Thread Starter
Re: 383 Needs harmonic balancer. which one?
Thanks all that what I need to know.
FastFred is offline
