69 Camaro LM1 350 255hp engine cam ?? - Team Camaro Tech
post #1 of 1 (permalink) Old Feb 22nd, 10, 10:18 AM Thread Starter
JDCAST
I have the 69 LM1 Camaro with the 350 255hp engine. I am getting some smoke out of the exhaust pipes and am going to do a compression test to see what the problem is.
I will probobly end up having the heads sent out and redone to correct this problem if the rings turn out to be okay. But I was thinking that it may be smart to replace the cam and lifters also at this time.
Can someone tell me which is the correct cam for this engine and what brand is a good one. I think Crane makes all these original cams again for these engines. Maybe I can bump it up a bit for a little more power. Suggestions by any of you that are knowledegable with this are appreciated.
My car is an RS SS so I need good vacuum for the headlights so I dont want to go too aggressive on the cam.
thanks all
John C
jdcastig is offline
