Brad Penn zddp lab test - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 22nd, 10, 04:27 PM Thread Starter
Tom P's Avatar
I recently switched to Brad Penn High Perf 10w-30 oil in my '69 with flat tappet cam. Its available at a local distributor (and affordable $4.39/qt). I was running Valvoline VR-1 10w-30 but it's been difficult to find in stock locally.
I picked up a mail order oil test kit (about $30) from Amsoil - they use a lab called Oil Analyzers Inc. http://www.oaitesting.com/to confirm the ZDDP levels.
Both oil samples were new - right out of the can:
Penn advertises 1500ppm/1340ppm (Zinc/Phosphorous)
Results 1428ppm/1215 - a little low but close to what they advertise
The lab also red flagged Sodium (775 ppm). I called Penn and they said Sodium is part of their "additive package". After I got the results I tested some left over VR-1.
Valvoline advertises 1400ppm/1300ppm (Zinc/Phosphorous) for VR-1 (10w-30)
Results 1200ppm/1073ppm
The detergent level (Calcium) was higher on the VR-1. Both samples went to the same lab, but were tested a few weeks apart. Scans of the lab reports are attached.
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline
post #2 of 6 (permalink) Old Feb 22nd, 10, 06:36 PM
ZZ_430's Avatar
Re: Brad Penn zddp lab test
I've been using the Brad Penn break-in oil lately with no problems. Good stuff IMO.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 6 (permalink) Old Feb 22nd, 10, 07:00 PM
Steiner
Cool, thanks.
I've been checking the Bob is the Oil Guy analysis forums to see what people are getting. Gonna try Rotella synthetic 5W-40 some time in the future....usually shows around 1350-1400 ppm zinc and they've got it at Wally World. If I hadn't already been laying out $$$ for three jugs of Mobil-1 for the daily drivers I would've picked some up the other day when I was there.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 6 (permalink) Old Feb 22nd, 10, 07:07 PM
Todd
The sodium level is interesting. I was going to use VR1 but my engine builder likes Penn. hmmmm
Vegas69 is offline
post #5 of 6 (permalink) Old Feb 22nd, 10, 07:18 PM Thread Starter
Tom P's Avatar
I agree!
Tom P is offline
post #6 of 6 (permalink) Old Feb 22nd, 10, 07:28 PM
"Tri-Tip"
Gary L's Avatar
Originally Posted by Tom P View Post
........The lab also red flagged Sodium (775 ppm). I called Penn and they said Sodium is part of their "additive package". After I got the results I tested some left over VR-1.........
Good thing. Sodium can mean coolant in the oil. That is how I learned I had leaking rocker studs.
Gary L is offline
