ZZ383 hood clearance intake question low or high rise - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 24th, 10, 05:41 PM Thread Starter
Rich
I am purchasing a ZZ383 and do not know if I have the hood clearance for the single plane high rise intake manifold (12496822)that the GMPP recommends or do I go with the duel plane (12366573) for a cost of 15-20HP. I have a 1968 coupe with the stock hood (not cowl). Is anyone running this engine with the single plane high rise intake with the stock coupe hood? Thanks for anyone's help.
rrobson1977 is offline
post #2 of 10 (permalink) Old Feb 24th, 10, 06:48 PM
DT
Donny
DT's Avatar
Re: zz383 hood clearance intake question low or high rise
I have an ss hood with a BBC under it and a Performer RPM manifold. I had to use Proforms dropped aircleaner base for it to fit. Its close, but it fits. Not sure if this info will help, but it may give you some baseline.
DT is offline
post #3 of 10 (permalink) Old Feb 24th, 10, 07:18 PM
Jeremiah
I think the Victor Jr and Team G are both approx to the RPM in hight.
I had a 6" K/N stuffed under a cowl hood with a dropped base cleaner, im sure a 3" would fit fine under the SS hood with a dropped base.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #4 of 10 (permalink) Old Feb 24th, 10, 07:35 PM
If this is a street car, I'd recommend the dual plane Performer RPM Vortec, which WILL fit under a stock flat hood when used with a GM drop base air cleaner and a 3" element. Not recommending the RPM jus because it'll fit, but because it'll perform better on the street(probably)
I doubt that GM makes that single plane intake - it's probably made by Edelbrock, and is probably a Victor Jr. or Super Victor. If you go to Edelbrock's site and dig around, you'll find measurements for their intakes, and you can compare with the Perf RPM.
BPOS is offline
post #5 of 10 (permalink) Old Feb 24th, 10, 07:56 PM
Jeremiah
I think your right, all of the GM Bowtie intakes I have seen look exactly like an Edelbrock offering with different markings. I agree also that the RPM intake would be a good match for the ZZ383's power and RPM range.
Jeremiah is offline
post #6 of 10 (permalink) Old Feb 25th, 10, 12:27 PM
Bill
Re: ZZ383 hood clearance intake question low or high rise
I do run the zz383 w/RPM air-gap dual plane - vortec manifold. I've got SS hood which has a tad more room than a standard hood - this combo fits w/room using a drop base 14 x 3". Course Edel vs. Holley carbs can make a diff as well and I'm runnin a standard holley. Can't recall which one provides for more clearance but do remember a difference. It's hard for me to say the single plane would be any better or worse but I do know that the engine is very responsive across the board with the dual plane. I went through same dilemna when I got that eng. and was steered toward the dual plane and have no regrets on a car that is mostly street driven with about 25 runs at teh drag strip ea. year.
68RS-SS is offline
post #7 of 10 (permalink) Old Mar 3rd, 10, 05:08 PM Thread Starter
Rich
Thanks guys for the info, I appreciate the help.
post #8 of 10 (permalink) Old Mar 3rd, 10, 09:25 PM
Lane
X's 2. I love my RPM air gap and it fits under my stock hood. You can click my link to see pics. FYI, I recently blew out the power valve in the Holley and rather than rebuild it, decided to bolt on an Edelbrock 800 AVS, which also fits under the hood (and for those who are wondering, the top end isn't as good as the Holley, but the throttle response is better).
Lane
rlyfst1 is offline
post #9 of 10 (permalink) Old Sep 24th, 14, 10:34 AM
Joe
I know this is old, but I can address the question for a 69, which may help people in the future. A zz383 with a single plane intake (12496822) will not fit under a stock 69 hood hood regardless of drop base air cleaner. I tried. The carb itself was hitting hood insulation.
joebobo32 is offline
post #10 of 10 (permalink) Old Sep 24th, 14, 07:10 PM
Anne
X2 on this. And be sure to get the vortec intake like Al said !
BTW, that's a killer engine (grudgingly said by a BBC fanatic)
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
