96-00 block dipstick question - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 26th, 10, 05:52 PM Thread Starter
Kevin
I have been doing a search on finding a dipstick for my new 383.
tried a couple that didnt work already.
Its a 350 block # 10243880 with dart heads. & dougs headers.
1996-2000 I believe.
I found a chevy part number for a zz4 , 12551144 & 1255154 tube and dipstick. Does anyone know if this will work.
Or is there and older stick that can work from a like year chevy??
69Rook is offline
post #2 of 8 (permalink) Old Feb 26th, 10, 06:08 PM
Re: 96-00 block dipstick question
Where is the hole, When you ask for a 96/00, people think of LS series, a lot of replacement blocks came with dual dipstick mounting holes, check your oil pan are there
dimples one side both sides, which side????
john68 is offline
post #3 of 8 (permalink) Old Feb 26th, 10, 06:50 PM
Bill
Kevin,
Order one for a 99 Tahoe 5.7 VIN "R" That is what is in my Tahoe. The dipstick is on the pass side. Not sure if it will clear headers or not, I will get a pic for you in the morning if you want ?
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #4 of 8 (permalink) Old Feb 26th, 10, 07:44 PM Thread Starter
Kevin
The hole is located on the passenger side, cant locate any "dimples" on the pan. Its an after market chrome pan that came with the motor.
Bill, do you have the same block number?
69Rook is offline
post #5 of 8 (permalink) Old Feb 26th, 10, 08:15 PM
Bill
Kevin,
Dont know about my block number, but it should be the same. The number you show is correct for a 99 Truck 350. I will take a look in the morning when I pull the Tahoe out of the garage.
Bill Koustenis
Owner
Waldorf Md
BillK is offline
post #6 of 8 (permalink) Old Feb 27th, 10, 10:31 AM Thread Starter
Kevin
Bill, I was wondering if its the same block numbers. Thanks
69Rook is offline
post #7 of 8 (permalink) Old Feb 27th, 10, 06:39 PM
Bill
Kevin,
I took a look at my Tahoe this AM. Too much junk in the way under the hood to see the casting number It should be the same as yours though, that casting number was used in those years.
You might not like the truck dipstick, it curves up and towards the front so you can reach it easily from the front of the truck. I could not get a picture, forgot I had the camera at the shop and did not bring it home
I would think that any passenger side dipstick for the late model blocks should work. I have a bunch of blocks at the shop and will take a look on Monday.
Bill Koustenis
Owner
Waldorf Md
BillK is offline
post #8 of 8 (permalink) Old Feb 27th, 10, 07:51 PM Thread Starter
Kevin
Thanks Bill, I am going to go and look at a late 90s camaro later and will try to see if that would work.
Seems like it should be an easy thing to do but so far its been a pain.
69Rook is offline
