Novice trying to figure something out - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 27th, 10, 11:33 AM Thread Starter
I have a 350 4-bolt main engine that has a cast number of 14016379 stamped on it and Goodwrench series on the valve covers, I am fairly sure that this engine did not come out of the '70 chevy c-10 truck it was in. Can anyone tell me if they know anything about this engine?
wandrinwizard is offline
post #2 of 5 (permalink) Old Feb 27th, 10, 11:40 AM
Gary
69Z28's Avatar
Re: Novice trying to figure something out
I found this on the Mortec website.
14016379...350...77-79...2 or 4
Locating the casting date on the rear of the block flange will help to establish when it was cast and the stamped numbers and letters on the pad on the block at the front of the passenger head should tell you what the engine was used in.
06A 1969 Camaro Z28 X33D80 69 B 711 Black Stripes Console w/tach and gauges.
69Z28 is offline
post #3 of 5 (permalink) Old Feb 27th, 10, 11:55 AM
Smile Re: Novice trying to figure something out
TJS69 is offline
post #4 of 5 (permalink) Old Feb 27th, 10, 01:10 PM
68driver57's Avatar
If 14016379 is the only number you have on the block then it was manufactured Sept. 4 1970. See if there are other numbers visible
68 coupe
matching 327
95 coupe (bone stock)
68driver57 is offline
post #5 of 5 (permalink) Old Mar 1st, 10, 11:25 PM Thread Starter
Thank You all for your help. Next I will find a good car to rebuild and put it in.
Tags
14016379, 350, goodwrench series
