Swapping engines from 6 cyl to 350 on 67 wondering about motor mounts - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 27th, 10, 02:31 PM Thread Starter
paul
I am swaping the 6 cyl in my 67 camaro with a 350 small block. Do I need to replace the original motor mount saddles and/or saddle brackets that are attached to the frame?
67 Novice
Paul Hogan is offline
post #2 of 10 (permalink) Old Feb 27th, 10, 03:51 PM
Re: Swaping engines from 6 cyl to 350 on 67 wondering about motor moun
Yes,
john68 is offline
post #3 of 10 (permalink) Old Feb 27th, 10, 04:15 PM
mark
NPD sells the motor mount brackets for the smallblock at $14.95 each.
mark191 is offline
post #4 of 10 (permalink) Old Feb 27th, 10, 05:02 PM
Whatever brackets you get, get the corresponding isolators to go with the brackets.
It is dependent of CID.
post #5 of 10 (permalink) Old Feb 27th, 10, 05:28 PM
Smile Re: Swaping engines from 6 cyl to 350 on 67 wondering about motor moun
TJS69 is offline
post #6 of 10 (permalink) Old Feb 27th, 10, 09:46 PM
Alex
The different brackets for small blocks are a result of the 8" harmonic balancer that was factory installed on the DZ302 and L48 350 engines. If your 350 has a 6" or 7" damper on it then I'd use what guys call the 327 mounts for their additional firewall clearance. It opens up your options regarding distributor choice to do so.
'69 Z28: X33 / 02B / non-matching 302 / Dart 200cc pro 1 platinum heads / Crower solid roller / matching M21 / matching BU axle / 4:11 ring and pinion
69duskblueX33 is offline
post #7 of 10 (permalink) Old Feb 28th, 10, 02:59 PM Thread Starter
paul
What are the isolators and what is the CID?
67 Novice
post #8 of 10 (permalink) Old Feb 28th, 10, 03:07 PM
Smile Re: Swapping engines from 6 cyl to 350 on 67 wondering about motor mou
isolators = engine mounts = motor mounts
frame mounts = frame brackets = frame stands
CID = Cubic Inch Displacement = engine size
TJS69 is offline
post #9 of 10 (permalink) Old Feb 28th, 10, 04:04 PM
x2 i bought mine at npd worked and everything lined up fine
67 RS 355sbc 11.76et @ 116mph 1.67 60' Deluxe Parchment interior
Bad67355 is offline
post #10 of 10 (permalink) Old Feb 28th, 10, 04:50 PM
Jerry R.
jr68's Avatar
Save the 6 and everything that comes with it when you do the swap. You'll be glad you did if you ever sell the car.
IMO those 6 cyl. Camaros are kind of rare.
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
