Clean ceramic coated headers - Team Camaro Tech
post #1 of 13 (permalink) Old Feb 27th, 10, 06:45 PM Thread Starter
I need some help. I was removing my spark plugs with the engine hot and got some of my mechanics glove burned on to the surface of my ceramic coated headers. I have only tried some brake clean on a rag but did not remove the stain. Any sugestions would be great. Mike
67 R/S Blue 406 518HP and 504TQ Dart block,Callies crank,Mahle pistons,Ultradyne cam 230/238 duration @.050 530 lift at 113 lsa, Afr 195 heads,Holley 4150HP carb and RPM Air gap. TKO600 with 373 gears
mike's blue67 is offline
post #2 of 13 (permalink) Old Feb 27th, 10, 08:28 PM
Re: clean ceramic coated headers
If it melted to it that easily will probably burn off next time you run it up to temp. I'd probably avoid chemicals or trying to scrape it off.
68 coupe ,572,tko
Denvervet is offline
post #3 of 13 (permalink) Old Feb 27th, 10, 08:57 PM
JcGc's Avatar
I had a rag touch mine and melt on two of the tubes. I used super fine steel wool and they look like brand new again.
1969 Camaro
JcGc is offline
post #4 of 13 (permalink) Old Feb 27th, 10, 10:19 PM
Harley D
HarleyD67's Avatar
steel wool (per my coater)
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #5 of 13 (permalink) Old Feb 28th, 10, 11:52 AM Thread Starter
Re: Clean ceramic coated headers
Thanks guys i will try the steel wool
post #6 of 13 (permalink) Old Mar 1st, 10, 12:20 AM
Dario
Man! I've been wondering this for some time too! I have a few glove marks too that don't come off when you run it again. Anything you get on them never seems to go away. I even have some oil staining from a valve adjustment. I'll have to try you guys' steel wool trick. Do you use some sort of liquid too... water... degreaser... anything or just dry steel wool?
67 RS Camaro
Originally: Stock 327/210 w/AC, 2 Speed Powerglide & Deluxe Interior
Now: Hotchkis SB TVS, Cross-Drilled/Slotted Disc Brake Conversion, 327/330, Headers w/ Pypes Dual Street Pros & more to come.
jet-tech1 is offline
post #7 of 13 (permalink) Old Mar 1st, 10, 04:55 AM
Harry
dawg's Avatar
ultra fine steel wool and some metal polish to finish.
434 stroker
US Navy retired
dawg is offline
post #8 of 13 (permalink) Old Mar 1st, 10, 11:52 AM
AJ
I used steel wool once, it looked really shiny in the small spot I used, I thought it removed some of the coating because it looked new.
Does it remove or damage the coating with ultra fine steel wool?
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #9 of 13 (permalink) Old Mar 1st, 10, 12:00 PM
Harry
dawg's Avatar
unless the headers are not real ceramic coated youll be fine.
ceramic is a lot harder than steel.
so steel wool wont make it come off
434 stroker
US Navy retired
dawg is offline
post #10 of 13 (permalink) Old Mar 1st, 10, 04:40 PM
Capps Brite Hot Coatings( CermaKrome coaters for Lemons Headers) states........
"Periodic cleaning of your headers can be accomplished by using a clean cloth with mineral spirits or any other cleaning products that do not contain caustics or acids. Once all foreign matter has been removed, the coating may be polished with a clean soft cloth and a nonabrasive polish such as wheel polish, Mothers Mag polish,Blu Magic, Metal Magic,Eagle One Mag polish or any other aluminum polish. Periodic scrubbing with a red or gray Scotchbrite pad may be useful in removing oils and contaminants from the coating surface."
David F.
www.firstgens.com
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #11 of 13 (permalink) Old Mar 30th, 10, 11:55 AM
Rene
rsbecool's Avatar
Had a leak on my power steering hose and fluid got on my jet hot ceramic headers during a road trip. when I got home they were in very bad shap to a point some areas were about black. I tried Flitz metal polish and it worked great. It all cleaned up to like new.
68 rs 350
M-20 4-speed
10 bolt 8.5 3.23
TC #24
rsbecool is offline
post #12 of 13 (permalink) Old Mar 31st, 10, 03:39 AM
Dario
Man! I went home the other day and tried the steel wool since I had some #000 laying around. What a difference! Haven't tried the mag wheel polish yet on it but the steel wool works great all by itself. Get ready to apply some elbow grease though.
67 RS Camaro
post #13 of 13 (permalink) Old Mar 31st, 10, 04:44 PM
Andy
Send a message via AIM to 67SS&99SS
I've used eagle one wadding polish on mine several times with great results.
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags
67SS&99SS is offline
