Why a Holley 1000 cfm with vacuum secondaries? - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 27th, 10, 08:28 PM Thread Starter
I am in the process of acquiring a Holley 1000 cfm annular and one down leg vacuum secondary carb. I can't figure out why in the heck Holley would build such a big carb with vacuum sec's. Makes about as much sense as the 750 dominator! lol
Does anyone know if there is a class out there with unlimited cfm but you have to run a vac sec? If not, any good guesses on what would run this type of carb? I guess a huge street motor. What's your thoughts? Thanks!
dubs68camaro is offline
post #2 of 7 (permalink) Old Feb 28th, 10, 03:03 AM
Re: Why a Holley 1000 cfm with vacuum secondaries????????????
For a boat maybe?
I think boats usually have vac secondaries. Not a very common use, but possible?
400bird is offline
post #3 of 7 (permalink) Old Feb 28th, 10, 05:26 AM
The same reason for having a 750 CFm w/vac secondaries - smooth transition.
If mech sec, open the sec's, and if a gallon of fuel isn't squirted at the samer time, the engine bogs.
post #4 of 7 (permalink) Old Feb 28th, 10, 08:43 AM
BILL
SPARKY69's Avatar
Is it a holley hp series?
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #5 of 7 (permalink) Old Feb 28th, 10, 12:32 PM
Eric
While vacuum secondary carbs lack the "sex appeal" of the double pumpers ( no double entendre intended), they can perform far better than many people are willing to give them credit for.
Carburetor Rebuild & Restoration
Engine & Driveline Parts & Services
Vintage Musclecar is offline
post #6 of 7 (permalink) Old Mar 3rd, 10, 10:53 AM
JohnZ's Avatar
Yup - L-88's had vacuum secondaries too.
JohnZ
CRG
JohnZ is offline
post #7 of 7 (permalink) Old Mar 3rd, 10, 12:17 PM
Eric
`67 L88: LIST 3418, 855 cfm vacuum secondary
`68 L88: LIST 4054, 855 cfm vacuum secondary
The `69 L88 & ZL-1's used a mechanical secondary 855 cfm carb, LIST 4296.
I run a `67 L88 (LIST 3418) carb on my 496. Works juuuuust fine.
