Engine rotation - Team Camaro Tech
post #1 of 12 (permalink) Old Feb 28th, 10, 01:29 PM Thread Starter
Engine rotation
i have to rotate my engine by hand to get to all of my torque converter bolts. does it matter which direction I rotate? I am rotating with a breaker bar from front. This is a new install and the motor has set for a few years. I suspect it is going to be a bit tough to turn. I have removed all plugs.
Clean 67 - 600hp / 579ft lb, 502
St Petersburg, FL
mccomas is offline
post #2 of 12 (permalink) Old Feb 28th, 10, 02:04 PM
ZZ_430's Avatar
Re: engine rotation
I like to turn them clockwise, but not from the harmonic balancer bolt.
This tool will make things much easier and safer.
http://www.jegs.com/i/JEGS/555/80530...oductId=751072
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 12 (permalink) Old Feb 28th, 10, 02:14 PM Thread Starter
Re: engine rotation
i am using the tool that attaches to the harmonic balancer. so from the engine front facing the engine i go counterclockwise or does it matter?
St Petersburg, FL
mccomas is offline
post #4 of 12 (permalink) Old Feb 28th, 10, 02:15 PM
Re: engine rotation
Clockwise looking at the front.
john68 is offline
post #5 of 12 (permalink) Old Mar 1st, 10, 08:05 PM
Shawn
Re: engine rotation
it doesnt matter which way you turn the engine over, the engine really doesnt care which way it goes.
back in the 70's a guy at the local oval track would run his engines backwards so the torque would push the tires down towards the ground on the bends and not up into the air
victimizati0n is offline
post #6 of 12 (permalink) Old Mar 1st, 10, 09:14 PM
"Tri-Tip"
Gary L's Avatar
Re: engine rotation
What tool is that?
Gary L is offline
post #7 of 12 (permalink) Old Mar 3rd, 10, 10:47 AM
JohnZ's Avatar
Re: engine rotation
Originally Posted by Gary L View Post
What tool is that?
Probably this one:
JohnZ
CRG
JohnZ is offline
post #8 of 12 (permalink) Old Mar 3rd, 10, 12:00 PM
"Tri-Tip"
Gary L's Avatar
Re: Engine rotation
I was wondering how something would work with the pulleys installed. Now I understand.
Gary L is offline
post #9 of 12 (permalink) Old Mar 3rd, 10, 04:14 PM
Keith
Re: Engine rotation
I have always used the balancer bolt...never a problem before...should I not do this?
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #10 of 12 (permalink) Old Mar 3rd, 10, 05:05 PM
Will
Re: engine rotation
Are you kidding me ????
Hatman is offline
post #11 of 12 (permalink) Old Mar 3rd, 10, 05:56 PM
Smile Re: Engine rotation
It is easy to strip the threads on a high compression engine.
TJS69 is online now
post #12 of 12 (permalink) Old Mar 3rd, 10, 10:14 PM
Steps
Re: Engine rotation
Just pull all the spark plugs out, and turn the flex plate leveraging with a long screwdriver or use a ring spanner on the flex plate bolts.....its not rocket science.
Steptoe is offline
