bending headers for clearance - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 2nd, 10, 02:47 PM Thread Starter
I bought a new set of polished ceramic shorties for a 67, they hit on the steering box, if I bang that area in a little will the ceramic chip or crack? I'll try to be gentle !!!
anyone else have that issue?
69RS
skip99 is offline
post #2 of 5 (permalink) Old Mar 2nd, 10, 03:06 PM
Bill
Re: bending headers for clearance
Mine came about 3/16th from the PS box and was almost ready to start pounding on them so interested on how this evolves. I did wrap that paricular tube with some heat barrier material to deter the heat from soaking into the PS box and fluid. Something you still may want to consider since such close proximity.
Also - originally I was at closer to 1/16" but ground some material off of the side of PS box (did the 3rd Gen Cardone swap which brought it a tad closer to the tube vs. original PS box). Nothing aggressive or that would hinder the integrity but gradual and smooth. This extra grinding resulted in about another 1/16" - 1/8" clearance in areas where tube came close to box.
68RS-SS is offline
post #3 of 5 (permalink) Old Mar 2nd, 10, 03:17 PM
Ed
BigBlock1969RS's Avatar
I had to bang on my Hooker Ceramic coated headers. I'd do it with a soft piece of aluminum stock rounded off:
If will scratch em, but not hurt the coating.
Ed
BigBlock1969RS is offline
post #4 of 5 (permalink) Old Mar 3rd, 10, 08:09 PM
Kevin
Depending on how much room you need you could just shim up the motor mount / block to move motor up and over to the right.
67 Viper Blue with White Z28 Stripes 540CI 675HP 690FT LBS 200R4 9" 3.70
67Kevin is offline
post #5 of 5 (permalink) Old Mar 4th, 10, 05:43 AM
Gary
A little bit of massaging won't hurt a thing, but use a piece of wood (or aluminum as Ed did) in the right spot, then hit that with your hammer. If you strike it directly, you'll definitely cause damage. I've seen several that were done with wood blocks and haven't seen any that were losing any of the coating material.
I'm kinda anal about mine, I always do the trial fit and massaging first, then send 'em off for coating.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Busted Knuckles is offline
