502 finally in - Team Camaro Tech
post #1 of 22 (permalink) Old Mar 2nd, 10, 06:08 PM Thread Starter
502 finally in
Finally got my motor placed inů working to terminate my cables, wires and hoses. Got a 200 r4 bolted up to it (BTO) and ordered headers today. Trying to figure out what to do with throttle linkage. Looks like my stock arm is going to hit the valve cover and it seems a bit short. I do not want to use a cable system unless good reason. Also having a tough time figuring out how to run -10 fuel feed. I have a great flaring tool but it only goes up to 1/2inů.
Clean 67 - 600hp / 579ft lb, 502
St Petersburg, FL
mccomas is offline
post #2 of 22 (permalink) Old Mar 2nd, 10, 06:12 PM
Jeff
Re: 502 finally in
Sweeeeeeeeeeet!
fordpowerjoke is offline
post #3 of 22 (permalink) Old Mar 2nd, 10, 07:55 PM
Vic
Re: 502 finally in
So f*****g jealous!!
Vic
1969 Camaro SS
Camaro1969 is offline
post #4 of 22 (permalink) Old Mar 2nd, 10, 08:06 PM
Lifetime Gold Member
Drew
ddx77's Avatar
Re: 502 finally in
That is beautiful!!! Congrats!
________________________________
1st Genless again - Working on getting my 69Z28 back.
ddx77 is offline
post #5 of 22 (permalink) Old Mar 2nd, 10, 08:23 PM
Tom P's Avatar
Re: 502 finally in
Looks good
Which intake are you running?
Is this a modified ZZ502 or a new build?
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline
post #6 of 22 (permalink) Old Mar 2nd, 10, 08:26 PM
Todd
Re: 502 finally in
Looks great so far
Vegas69 is offline
post #7 of 22 (permalink) Old Mar 2nd, 10, 08:35 PM
Re: 502 finally in
WOOOOWWW Looking good!
67 Camaro with 388 with Edleborck RPM heads, Air Gap, CC 282S, Tremec TKO
LukeSkywalker is offline
post #8 of 22 (permalink) Old Mar 2nd, 10, 09:24 PM
Re: 502 finally in
Good job. Looks killer and quite the exciting time . Before you get her all plumbed in are you sure you can get the headers in without lifting the engine ? I know I won't .
68 coupe ,572,tko
Denvervet is offline
post #9 of 22 (permalink) Old Mar 2nd, 10, 09:46 PM
Kevan
K and K's Avatar
Re: 502 finally in
Great so far, keep us updated.
67 RS
540, T-56 Magnum 6 Speed, 12 Bolt w/4:10's
(I haven't changed anything that can't be changed back)
Nicole:
My build thread:
K and K is offline
post #10 of 22 (permalink) Old Mar 2nd, 10, 10:31 PM
Skip
Skeeter55's Avatar
Re: 502 finally in
Bad a$$ thats for sure... I think you may have to run a full throttle cable. Check out this link for fuel lines http://www.getdiscbrakes.com/
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #11 of 22 (permalink) Old Mar 3rd, 10, 08:02 PM
Kevin
Re: 502 finally in
Nice!!
67 Viper Blue with White Z28 Stripes 540CI 675HP 690FT LBS 200R4 9" 3.70
67Kevin is offline
post #12 of 22 (permalink) Old Mar 4th, 10, 04:38 AM
BILL
SPARKY69's Avatar
Re: 502 finally in
DONT FORGET TO POST YOUR PICS HERE ALSO!!
https://www.camaros.net/forums/showthread.php?t=169199
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #13 of 22 (permalink) Old Mar 4th, 10, 05:33 AM Thread Starter
Re: 502 finally in
I am prepared to lift the motor a bit for header install. I ordered Lemons' race headers on Monday and hoping that I will be able to slip them in a few cylinders at a time.
I picked up the motor about 2 years ago and have been busy transiting jobs and homes. I have just about rewired everything under the hood and cabin. This started as a 67 327 and I had to do a lot of small block to big block stuff...
My long pole in the tent remains to be fuel system. I did a lot of research in picking my fuel system and really cannot figure out how to plum -10 fuel feed. I am running an A1000 in-tank pump in a "Rick's Tank". The issue is flaring and bending the -10 feed. I have a mastercool flaring tool that I used for all my brake lines but it only goes up to 1/2 inch. I have always heard that if I use braded line from tank to engine, I will smell fuel. I really need some input here in order to move forward. My goal is to start motor by 1 May.
St Petersburg, FL
mccomas is offline
post #14 of 22 (permalink) Old Mar 4th, 10, 08:30 AM
Skip
Skeeter55's Avatar
Re: 502 finally in
Just use a compression fittings no need to flare.
post #15 of 22 (permalink) Old Mar 4th, 10, 09:28 AM
prostreet69camaro's Avatar
Re: 502 finally in
I used #10 from the tank to the filter then #10 from the filter to the pump. Then #8 from the pump to my fuel pressure regulator. This is on a 502 w/8-71 blower feeding 2 -750 carbs. 1/2" or #8 is plenty line to feed your motor. I have a small piece of #8 braided line from the pump to my hard line. That is on both ends of the hard line. You can use 1/2" aluminum line and use the flare tool you have. They sell flare nuts and inserts for the 1/2" line.
prostreet69camaro is offline
