1987 Iroc 305 - 4 barrel carb choke...chokes - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 2nd, 10, 10:17 PM Thread Starter
Question 1987 Iroc 305 - 4 barrel carb choke...chokes
Have situ with choke indicator light staying on even after car is warm. Choke stays engaged. What systems cause the choke to go on so I can try to back out the problem. Ideas for tracking down cause? Many thanks
BudgetRacing is offline
post #2 of 6 (permalink) Old Mar 2nd, 10, 11:25 PM
Jay
Re: 1987 Iroc 305 - 4 barrel carb choke...chokes
Bad choke coil
Juicer2 is offline
post #3 of 6 (permalink) Old Mar 2nd, 10, 11:32 PM Thread Starter
Thanks, Juicer. Sorry, I forgot to mention that I replaced the choke coil but I'm still having issues. Any other thoughts? Thanks!
post #4 of 6 (permalink) Old Mar 3rd, 10, 04:39 AM
Dan Ensign
Do you have power at the choke connector, does the choke flap move freely, not binding? Can you feel the resistance of the choke coil when moving the flap, Fuse ok, also I have seen the terminal back out of the connector so you don't get a good connection at the choke coil.
Dan E.
69 SS396 4spd. 4.10 posi. x66 coupe
Dan E. is offline
post #5 of 6 (permalink) Old Mar 3rd, 10, 11:15 AM
is the oil pressure sender plugged in? that's where the choke coil gets it's power.
you don't plan sincerity.
novaderrik is offline
post #6 of 6 (permalink) Old Mar 4th, 10, 08:10 AM
greg
I had the same problem on my 87 Formula, choke was always screwed up and a rebuild did not help. I lived in Fla. at the time so took the choke blade out completely and had no problems after that.
docwilcar is offline
Tags
1987, carborator, choke, iroc
