87 iroc water pump removal question - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 3rd, 10, 12:47 PM Thread Starter
Hi Guys,
I have an 87 iroc, 305 tpi, ac. I've gotten all of the brackets off to remove my water pump except the ps bracket. How do I do this? I can't get this thing off. I see three bolts, 1 bottom, 1 block , and 1 into water pump. Is there anyone?
sobo is offline
post #2 of 4 (permalink) Old Mar 3rd, 10, 05:10 PM
Re: 87 iroc water pump removal question
is there a bracket going to the front exhaust manifold bolt?
i thought the TPI motors had serpentine setups on them- which would mean the water pump would come right out with 4 bolts after the belt was removed, with the big aluminum brackets still bolted in place.
you don't plan sincerity.
novaderrik is offline
post #3 of 4 (permalink) Old Mar 3rd, 10, 05:53 PM
ZZ_430's Avatar
Sobo, do you have a pic?
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #4 of 4 (permalink) Old Mar 3rd, 10, 07:03 PM Thread Starter
Wow, that bracket didn't budge but I was able to move it enought to change the pump. Fun stuff.
Thanks again guys.
sobo is offline
